New to HA. I originally had zigbee2mqtt set up on HA then moved to ZHA.
I removed all references to zigbee2mqtt but keep getting the following message:
I don’t this this is related to zigbee2mqtt.
When you use a zigbee network you need to define a network key, and probably ZHA use the same network key of zigbee2mqtt.
Probably there is a way to change this key but you need to pair all your devices again.
I have the same message after moving away from zigbee2mqtt a long time ago. Is there another way to get rid of the message? I’m not looking forward to repairing and renaming all my devices…
