ZigBee2MQTT Error - unblocking Device
Hello everyone,
I have a small problem with Zigbee2MQTT.
I accidentally deleted a device and blocked it at the same time.
This device is also shown as blocked in Z2M.
However, if I now want to remove it from the blocked devices (minus behind the blocked device), I only get an error message:
blocklist must be array
Request ‘zigbee2mqtt/bridge/request/options’ failed with error: ‘blocklist must be array’
How can I unblock the device again?
Thank you in advance
Andreas
Known problem. Fixed in next major release.
Until the next version is released, you can manually edit Zigbee2MQTT’s configuration.yaml file and remove the device from the blocklist section (then restart Zigbee2MQTT to have the change take effect).
