Your battery health figures will then be slightly off in comparison with others, no problem of course.
But around 100% is not very interesting IMO. I’m more interested when the battery comes near 2.80 -2.70 Volt range. Then I know the battery comes to end of life with a steep fall off and probably I have around 10% left and need to change the battery!
For example Xiaomi gives a life expectancy of two years for their sensors (with CR2032 batteries), so there will still be weeks left to change the battery before they stop working (I suppose because I haven’t any clue at what voltage level they stop working).
My oldest Xiaomi / Aqara sensors are about a year old and still pretty healthy.
Hey all, is there a wiki page which explains how to create battery sensors for the various devices? I have added a few based on searching through this page but Im not sure exactly what is the code I need. I have added a few but Im waiting to check if they get a value at some point before adding the rest.
Ok turns out I was being stupid. The tap event DOES in deed work. I was simple tapping the top of the cube expecting that to register but after watching a review video on YouTube I understand that to trigger the tap you have to physically lift the cube and tap the it on a surface TWICE.
The downside of receiving instructions in Chinese .
Hi, couldn’t work out how to add a pull request to zigbee-shepherd-converters so have posted the code to add Osram SMART+ Spot GU10 Multicolor bulbs in the issues instead, hopefully you can use it like that.
They’re just the same as the other Osram RGBW bulbs you already have bar the change of ID, name etc, so hopefully an easy add.
I connected a Xiaomi double wireless wall switch and it works great but does anyone know if it’s supposed to display the battery automatically as an attribute or do I need to configure a template battery sensor myself?
Just received my water sensor today. If you look at pics on the chinese instruction booklet, you will see a pic of squeezing the center of the sensor. this is a waterproof sensor with no visible pairing button that I can see. I put the bridge in pairing mode and then squeezed the sensor for a few seconds, it paired for me:
Did you go through any particular process to pair the double wireless wall switch? I’ve paired about 12 other devices but this one keeps failing for me.
I don’t really remember sorry, I think I held both for a couple of seconds and then you have to keep it alive by pressing either switch every few seconds. Hope that works.
I’m having a problem with devices being recognised and added to configuration.yaml and database.db, but then they stop working and no longer send any MQTT messages.
