Yes you need to configure zigbee2mqtt via it’s configuration.yaml file, as specified in the instructions.
yes I did but I don’t see any device in my entities screen in HA
Use mosquitto_sub to see if zigbee2mqtt’s mqtt messages are being received by your mqtt broker.
- do you have mqtt discovery set up in home assistant?
- do you have homeassistant: true set up in zigbee2mqtt?
You need to reboot HA in order for it to pick up the new entity
Every time I make a change to the configuration.yaml in the zigbee2mqtt folder this file get overwritten even if I set overwrite to false. Or should I setup mqtt discovery in the normal configuration.yaml file.
Yes the fact that zigbee2mqtt has it’s config in a file called configuration.yaml which is completely unrelated to home assistant’s own configuration.yaml file is confusing isn’t it.
So if I put this in the normal configuration file it should work.
But what should be the client id ?
mqtt:
broker: a0d7b954-mqtt
username: !secret mqtt_username
password: !secret mqtt_password
client_id: home-assistant
Still no devices in my entities.
I don’t know anymore.
I hope anyone has a good suggestion what to do
Post your config properly. The instructions are at the top of every forum page
actitudes like yours really discourage contributing in a forum
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 51.85083189038637
longitude: 5.854850127034183
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Amsterdam
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
# introduction:
mqtt:
discovery: true
username: xxxxxx
password: xxxxxxx
# Password login for api
http:
api_password: !secret api_password
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
ignore:
- plex_mediaserver
influxdb:
host: a0d7b954-influxdb
port: 8086
database: p1smartmeter
username: !secret influxdb_user
password: !secret influxdb_pass
max_retries: 3
default_measurement: state
input_boolean:
zigbee_permit_join:
name: Allow devices to join
initial: off
icon: mdi:cellphone-wireless
timer:
zigbee_permit_join:
name: Time remaining
duration: 600
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
logger:
default: info
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
sensor: !include sensor.yaml
# Text to speech
tts:
- platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
binary_sensor: !include binary_sensor.yaml
rfxtrx:
device: /dev/ttyUSB0
debug: False
# switch settings
switch:
platform: rfxtrx
automatic_add: True
devices:
0b11000801ea156a01010f60:
0b110004012a035a01010f50:
0b11000f012a035a02010f50:
'0710010047040000':
0b110008017199920a000060:
"0710020047050000":
0b11000201ea156a02010f70:
And this is the one from zigbee2mqtt:
devices:
'0x90fd9ffffed52d24':
friendly_name: ikeabootlamp
retain: false
homeassistant: true
mqtt:
base_topic: zigbee2mqtt
password: XXXXXXX
server: mqtt://homeassistant
user: XXXXXXX
permit_join: false
serial:
disable_led: true
port: /dev/ttyACM0
Seemed to fix the issue. The user I used was on readonly in the mqtt config. I changed it and I now see an entity coming in. Thnxs for the help.
You do not need to restart ha for that.
Anyone selling a preflashed cc2531? Buying the flasher seems a waste. Will give the seller some extra bucks off course.
Ships to Hawaii?
Not if you ever want to update the firmware on it or flash a few CC2531 with the router firmware too
True, for me just 1 without router is fine. If I ever want to update or flash others I will buy it.
I am a beginner, I am a bit confused by the steps. Do I need to pre setup mqtt in hassio. What mqtt broker is recommend. The build in one works fine or I need something like mosquito.
mosquitto is recommended over the built in broker. It is just better.
Can somebody help me with zigbee groups on Hass.io?
I have a separate groups.yaml file which I include in the config.yaml. Where should I create the zigbee group?
Also, when I tried to create one, it said “Friendly name” wasn’t a valid thing.
Lastly, to add items to a group do I just publish an mqtt topic?
If you have a groups.yaml then the logical place to create a group is in that file.
As for the rest of your question, it is probably answered here https://www.home-assistant.io/components/group/ - unless I am missing something.
