I was doing to things in HA, as I am rebuilding my HA instance — which has been great to do after 7 years of running a totally polluted and hacked about HA… It was how I learned a lot
Any way, one of the changes was moving to Zigbee2MQTT – which is amazing BTW!
I manually turned on a Sengled white bulb on using a simple knob switch on a bulb outlet plug. The light is paired and works just fine with Zigbee2MQTT, HA, NodeRed, triggered with automation by Hue switches and Hue motions, etc. All good. I can see the bulb in Z2M just fine.
I walked away to do something and left the light on. I came back and jumped into HA to do something and noticed that the light was showing in “off” state in HA.
I checked the Z2M logs and I can see it publishing to the logs the state, brightness, etc. Checked the HA logs and I don’t see anything.
So I’m thinking there is some message publishing or configuration options I’m missing - where Z2M should tell what it knows about a device in such scenario?
I can easily sync them back up – turning on/off a switch or triggering the motions, but that sounds like the wrong way.
After some fun, hallucination, misled and obsession to resolve the correct way, I found the fix was simple had I just slowed down and taken a little time to read documentation.
Updated the availability: section of the Z2M configuration.yaml as follows:
Are you sure ChatGPT didn’t hallucinate some of those options? The entire advanced section seems to be MQTT-specific settings and I suspect Z2M is ignoring them. None of those advanced options seem to be listed in Z2M docs
Because I have experience with LLMs, I for sure was skeptical and realized I may receive the exact feedback you shared.
This is a case of me not knowing any better and I wasn’t doing any damaging configuration to my HA environment. So I backed everything up and made the changes to the Z2M config. I couldn’t find an instance where something I configured popped an error somewhere - including in the Z2M addon and Z2M console logs (at debug level). It would be nice if it would inform what it’s ignoring to help. But the fact remains that after making these changes, the initial problem I was having was resolved. In all honestly, I was hesitant to post my resolution, knowing that it could have hallucinated, but the problem is resolved.
Now I’ll make take the time to work this all backwards now and see exactly what works and what doesn’t. Good way to learn since I have a working situation.
And you my friend have helped me track down the proper fixes! After your comments, I was bothered and felt compelled to research more, learn, and figure this out the right way. And you are right. And because it’s Friday in the US, I happen to have more time today to work on this
So I removed everything I added from the advanced: section Z2M configuration.yaml which basically set it to default config.
I then modified to update the availability: section of the Z2M configuration.yaml as follows:
Performed all testing - with that config and with it disabled and guess what? Everything works, meaning this was all that was needed. Removing the config, and I end up back with original problem. So it’s clear that’s all that was needed to begin with. How embarrassing! But just like the earlier hallucination learning expedition, I did learn! I’m humble and it’s all good! This is one of the rare moments I didn’t try things on my own. I let the new-ness of Z2M scare me a bit. Glad it’s resolved the right way now and I have a good understanding based on the documentation!
Thank you again @ShadowFist for pointing this out.
Hi, Hoping you can help me with this problem. I switched from ZHA to Z2M because I needed support for a new device that wasn’t supported properly by ZHA.
Everything went smoothly, except I noticed I’m having the same problem as the62694. None of my Sengled bulbs will show they are turned on when manually turned when the power is applied. I didn’t have this problem with ZHA.
I tried adding the same fix mentioned above and didn’t see any difference. Any suggestion on what setting needs to be applied so I can see when the bulb is on when power is applied?
First things first - I’m assuming you restarted Z2M for your yaml setting to take effect, right?
Secondly, you don’t need to do it in yaml. You can do everything in the Z2M Frontend (the one in the left sidebar, not the addon itself).
Go to Z2M > Settings > Availability tab > Select Availability (Advanced).
Set your preferred settings for active & passive devices in minutes (remember that most Sengled bulbs are considered passive end-devices) > Hit Submit
Thanks for the reply. I did try the above mentioned fix and it doesn’t appear to be working with the Sengled bulbs I have. After making the changes in the Z2M frontend, clicking submit, and restarting Z2M, I checked the configuration file for Z2M and availability is showing.
I don’t have another brand of Zigbee bulbs to be able to determine if it is the Sengled bulbs that aren’t sending out their state when power is turned on or something with my setup.
It should be easy to double check this by going to the Device page in Z2M for your Sengled bulb. It will probably be marked as an end device (passive) and not a router (active)
I did try the default 10 min for active and 1500 min for passive. With no difference.
When I changed the passive timeout to 1 min to test. The bulb will show unavailable after 1 min when power is removed. When power is applied, the bulb will turn it on, show availabe again and show the correct state as on for the bulb. The problem is after 1 minute, with no change to the power, the bulb will show unavailable. When this happen, the bulb(and other passived zigbee devices) will be grayed out and not controllable from the HA dashboard.
1 min is too low for passive devices I think. You’re gonna flood the network, have false alerts of devices being offline (battery devices only check in once in a while) and drain the batteries.
If I set it to 15-20min, wouldn’t the bulb then go offline and I wouldn’t be able to control them? That seems to be what is happening when I test the 1min timeout setting.
I feel like I’m missing something since I’m not getting any identication that the bulb is sending anything to Z2M that the bulb is on when it is powered on. Is there somewhere I can see if anythng was sent by the bulb?
OK…still messing around. When I look at the Z2M log in add-on, I can see when I manually turned the lamp on in the log. The problem is it publishing it at “state”:“OFF” when the bulb is on.
No, it probably won’t go offline if it reports back to Z2M within those 15 min, same as it didn’t go offline when the timeout was set to 25 hours (default).
What you could do is go to the Reporting Tab for each of your bulbs and configure reporting for the OnOff cluster, like this (use the values in my screenshot to get immediate reports):
@ShadowFist By any chance, is there a similar setting available for Phillips bulbs? I can apply this to Sengleds, but how about Philips bulbs for instant notification. It’s funny, but this was the actual problem I was trying to solve. How far and valuable this thread became!
Glad you got your problem solved - also solved for my Sengleds!
I don’t own any Philips bulbs but the procedure should be the same.
Only difference I can think of is that Hue bulbs are routers, so they are active devices if messing around with the availability settings. The reporting settings above should work though.
EDIT: Just to be clear, you really shouldn’t be cutting power to ZigBee routers like Hue bulbs. Any other devices using them for the ZigBee mesh will be kicked off and have to find an alternate route.
I suggest you get a smart switch with decoupled mode for these bulbs.
Thank you for this. I recently switched from hubitat which updated the state within seconds but by default home assistant didn’t do that until I implemented the solution you mentioned.
I had the same issue but with almost all my lights/switches. I thought it was my RaspBee II, so I bought the new Home Assistant Connect ZBT-2 and… the error persisted. I tried what @ShadowFist mentioned and it worked. The thing is that I had that cluster under reporting already.
So, for the other devices (all of them) what I did is to use the “Reconfigure” option. And that worked as well!
So, to anyone having the same issue, try first the “Reconfigure” option, it is faster.
