Zigbee2mqtt Interview failed because can not get node descriptor"
I myself bought two new Frient SMSZB-120 and wanted to add them to the 2 existing smoke alarms from Frient (same type) this week. I get the “Interview failed because can not get node descriptor” with both new detectors. Also when I remove one of the two detectors that was already paired for several months and try to pair it again, I also get the message “Interview failed because can not get node descriptor”. I see several other messages with all kinds of solutions here and on Github such as replacing the battery, rebooting, etc. but nothing helped. What can I contribute to possibly solve this or am I hijacking the wrong topic?
Zigbee2MQTT version
2.4.0 commit: unknown
Coordinator type
EmberZNet SLZB06M
Coordinator revision 8.0.2 [GA]
Frontend version 0.9.13
zigbee-herdsman-converters version 23.53.0
zigbee-herdsman version 4.1.0
What method are you using to remove the devices?
Aer there still related entries for these devices under the Devices tab in the Z2M web UI?
Hello, I have forced removed the detector and then there are no more devices in the tab of the UI of zb2mqtt. Also not under devices > entries of HA itself. Incidentally, as an experiment with another stick ZHA added to HA and it sees the smoke detectors at once:-(
Do you have ZHA and Z2M running simultaneously?
Only to test if it was a defect of the fire detector.ZHA pairs it correctly.
Honestly, that’s a good thing in some regards. I think testing ZHA was a great method to eliminate possible issues. I’ll have to dig a little more!
@Lampie01 Did you get any solution? I have exactly the same problem - one of my Frient detectors died (zigbee module failed) and I got replacement and cannot add it. I have 4 other ones working fine.
Yes and no, after the test i switch from de SLZB-06M to SLZB-06 (other radio chip, the M was Ember) and it was able to connect. So if it was EMber ? i dont no, but because it was solved for me left it. My first radio was the same chip as the SLZB-06…
