I’m currently running HA on a Raspberry Pi 3, and trying to use Zigbee2MQTT. I have set up the MQTT Broker add-on, which seems to be running fine. I also have the SONOFF Zigbee Dongle-E, which I flash with Silabs Firmware Flasher.
I have configured Zigbee2MQTT and it starts sometimes, but not others, and when it does start, it will crash within a few hours at most, watchdog will sometimes restart it, but not always. (I am using the ‘ezsp’ adapter, but ‘ember’ has the same results.
I’ve been working on this for a while now, I have reflashed the dongle, reinstalled both the MQTT Broker and Zigbee2MQTT. I am using a 2m USB extension cable, and neither the Pi or the Dongle are near a wifi router. Any help with this would be appreciated.
**MQTT Broker**
ogins: []
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
active: false
folder: mosquitto
**Zigbee2MQTT Configuration**
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
server: mqtt://core-mosquitto:1883
user: mosquitto
password: password
serial:
port: >-
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ba5b4c522ee2ed118d9df25162c613ac-if00-port0
adapter: ezsp
watchdog: default
