Zigbee2mqtt lqi 0
Hi, how do I associate a Zigbee device with lqi 0 (it doesn’t get the signal) to a router or repeater device to amplify it?
Try pairing it near the repeater.
But if you are then moving it out of range of any repeater, or it is a zigbee v1.0 device that can’t change its route, then it will stop working once out of range. The solution in that case is to add more repeating capable devices to give you more coverage.
