Greetings all:
i recently installed a slzb-06 and zigbee2mqtt. The install went as smoothly as i expected. I then paired 2 presence detector ( HOBEIAN), which paired without any issues. Both show in the z2m dashboard. The presence shows false or true appropriately, as does the temperature, light, humidity.
But no now devices show up in Homeassistant. So I looked in MQTT Explorer and found:
zigbee2mqtt/Sleeping Porch Presence z2m. As the topic and the json message:
"anti_interference": "ON",
"battery": 90,
"detection_distance": 5,
"device": {
"applicationVersion": 151,
"dateCode": "12052026",
"friendlyName": "Sleeping Porch Presence z2m",
"hardwareVersion": 1,
"ieeeAddr": "0xa4c1380f3e814033",
"manufacturerID": 4742,
"manufacturerName": "HOBEIAN",
"model": "ZG-204ZX",
"networkAddress": 48403,
"powerSource": "Battery",
"softwareBuildID": "0112052026",
"stackVersion": 2,
"type": "EndDevice",
"zclVersion": 3
"fading_time": 60,
"humidity": 53,
"humidity_calibration": 0,
"illuminance": 1491,
"illuminance_interval": 1,
"indicator": "OFF",
"linkquality": 153,
"motion_detection_sensitivity": 5,
"presence": false,
"static_detection_sensitivity": 4,
"temperature": 69.6,
"temperature_calibration": 0,
"temperature_unit": "fahrenheit"
The presence changes from true to false as expected.
So I know mosquitto is working as is the slzb-06 coordinator.
So I tried adding some configuration.yaml code for my mqtt.yaml for a binary-sensor:
binary_sensor:
- name: Sleeping Porch Presence z2m
unique_id: "Sleeping Porch Presence z2m"
state_topic: "zigbee2mqtt/Sleeping Porch Presence z2m"
value_template: "{{ state_json.presence }}"
payload_on: "true"
payload_off: "false"
but nothing shows up when I search under entities.
I'm stuck!
Any suggestions would be greatefully appreciated!
Thanks!
