Zigbee2MQTT not starting after upgrade
I upgraded yesterday and now Zigbee2MQTT won’t start. There haven’t been any hardware changes.
I’m desperate because I run the heating, lights, and security off od Zigbee2MQTT. Any and all help much appreciated.
Below is the Zigbee2MQTT log from the start.
11:32:08] INFO: Preparing to start...
[11:32:08] INFO: Socat not enabled
[11:32:09] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:debug 2023-11-02 11:32:12: Loaded state from file /config/zigbee2mqtt/state.json
Zigbee2MQTT:info  2023-11-02 11:32:12: Logging to console and directory: '/config/zigbee2mqtt/log/2023-11-02.11-32-12' filename: log.txt
Zigbee2MQTT:debug 2023-11-02 11:32:12: Removing old log directory '/config/zigbee2mqtt/log/2023-11-02.11-29-34'
Zigbee2MQTT:info  2023-11-02 11:32:12: Starting Zigbee2MQTT version 1.33.2 (commit #unknown)
Zigbee2MQTT:info  2023-11-02 11:32:12: Starting zigbee-herdsman (0.21.0)
Zigbee2MQTT:debug 2023-11-02 11:32:12: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/config/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","databasePath":"/config/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"path":"/dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0"}}'
Zigbee2MQTT:info  2023-11-02 11:32:12: zigbee-herdsman started (resumed)
Zigbee2MQTT:info  2023-11-02 11:32:12: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20221226,"transportrev":2},"type":"zStack3x0"}'
Zigbee2MQTT:debug 2023-11-02 11:32:12: Zigbee network parameters: {"channel":11,"extendedPanID":"0x00124b0026b6ab93","panID":6754}
Zigbee2MQTT:info  2023-11-02 11:32:12: Currently 65 devices are joined:
Zigbee2MQTT:info  2023-11-02 11:32:12: Plug - Guest bedroom (0x00124b0026b80867): S26R2ZB - SONOFF Zigbee smart plug (Router)
Zigbee2MQTT:info  2023-11-02 11:32:12: Plug - Master Bedroom (0x7cb03eaa0a09ce65): AB3257001NJ - OSRAM Smart+ plug (Router)
Zigbee2MQTT:info  2023-11-02 11:32:12: TH - Living Room (0x00124b0024cc9634): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Plug - Sunroom (0x7cb03eaa0a09c154): AB3257001NJ - OSRAM Smart+ plug (Router)
Zigbee2MQTT:info  2023-11-02 11:32:12: Fire - Kitchen (0x0015bc0034000cb1): HESZB-120 - Develco Fire detector with siren (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Smoke - Kitchen (0x0015bc0031009b46): SMSZB-120 - Develco Smoke detector with siren (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Plug - Entrance (0xf0d1b8be2408a298): 4058075729322 - LEDVANCE SMART+ Compact Outdoor Plug EU (Router)
Zigbee2MQTT:info  2023-11-02 11:32:12: Plug - Laundry (0x7cb03eaa0a09e4db): AB3257001NJ - OSRAM Smart+ plug (Router)
Zigbee2MQTT:info  2023-11-02 11:32:12: Plug - Social Bedroom (0x7cb03eaa0a094ea4): AB3257001NJ - OSRAM Smart+ plug (Router)
Zigbee2MQTT:info  2023-11-02 11:32:12: Plug - Kitchen (0x7cb03eaa0a0914b1): AB3257001NJ - OSRAM Smart+ plug (Router)
Zigbee2MQTT:info  2023-11-02 11:32:12: Plug - Master Bathroom (0x7cb03eaa0a0a53c0): AB3257001NJ - OSRAM Smart+ plug (Router)
Zigbee2MQTT:info  2023-11-02 11:32:12: Plug - Guest Bathroom (0x7cb03eaa0a0a0c9d): AB3257001NJ - OSRAM Smart+ plug (Router)
Zigbee2MQTT:info  2023-11-02 11:32:12: Smoke - Upstairs Hall (0x0015bc0031009eee): SMSZB-120 - Develco Smoke detector with siren (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Window - Office (0x00158d0008741f7c): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Door - Master Bedroom (0x00158d00070b18d4): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Motion - Master Bedroom (0x00158d000836e322): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Window - Master Walk-In (0x00158d000895923f): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Window - Master Bathroom (0x00158d00070b03d8): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Motion - Guest Bathroom (0x00158d0006b797e8): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Window - Guest Bathroom (0x00158d0008913a4d): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Window - Guest Bedroom (0x00158d000799f689): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Plug - Master Walk-In (0x00124b0026b82798): S26R2ZB - SONOFF Zigbee smart plug (Router)
Zigbee2MQTT:info  2023-11-02 11:32:12: Plug - Stairs (0x00124b0026b751f9): S26R2ZB - SONOFF Zigbee smart plug (Router)
Zigbee2MQTT:info  2023-11-02 11:32:12: Door - Office (0x00158d000799f9ee): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Motion - Entrance (0x00158d0004041e52): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Door - Front (0x00158d00079971ec): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Window - Sunroom - Right (0x00158d00089596bc): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Window - Sunroom - Center (0x00158d0008913480): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Door - Guest Bedroom - Right (0x00158d0007259993): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Window - Living Room (0x00158d00089203f1): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Motion - Living Room (0x00158d00085482c9): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Door - Dining Room - Right (0x00124b0022ff5b02): SNZB-04 - SONOFF Contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Door - Dining Room - Left (0x00158d0007d1dc45): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Motion - Dining Room (0x00158d0006b22976): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Motion - Sunroom (0x00158d0006b639ce): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Door - Kitchen (0x00158d0008a56286): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: TH - Kitchen (0x00124b0024cd0441): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: TRV - Social Bedroom  (0xa4c138c8571a3555): ME167 - AVATTO Thermostatic radiator valve (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Door - Laundry (0x00158d000799f789): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Window - Laundry (0x00158d0008741f6b): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Motion - Laundry (0x00158d0006b7c2fb): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Window - Social Bedroom (0x00158d0008a55d33): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Motion - Social Bedroom (0x00158d0006a240c7): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Motion - Kitchen (0x00158d0006b7c5ec): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Switch - Radiator Pump (0x00124b0024c0ceb9): ZBMINI - SONOFF Zigbee two way smart switch (Router)
Zigbee2MQTT:info  2023-11-02 11:32:12: Switch - Entrance Hall (0xa4c13850c8c284b2): TS0012 - TuYa Smart light switch - 2 gang (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Window - Kitchen - Right (0x00158d0007d121ef): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Window - Kitchen - Left (0x00158d0008a6cc3d): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Motion - Office (0x00158d00085482d9): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: TH - Sunroom (0x00124b00247077d1): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: TH - Office (0x00124b0024cd0ef6): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Plug - Living Room (0x00124b0026b8295c): S26R2ZB - SONOFF Zigbee smart plug (Router)
Zigbee2MQTT:info  2023-11-02 11:32:12: Motion - Guest Bedroom Too (0x00158d000250cb4d): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Plug - Upstairs Hall (0x7cb03eaa0a0a6038): AB3257001NJ - OSRAM Smart+ plug (Router)
Zigbee2MQTT:info  2023-11-02 11:32:12: Door - Guest Bedroom - Left (0x00158d0006f8249b): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: TRV - Office (0xa4c1385118206567): ME167 - AVATTO Thermostatic radiator valve (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: TRV - Upstairs Hall (0xa4c138eea8d1082f): ME167 - AVATTO Thermostatic radiator valve (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: TRV - Guest Bedroom (0xa4c13859bf4548a0): ME167 - AVATTO Thermostatic radiator valve (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: TRV - Kitchen (0xa4c1387f108f4d5c): ME167 - AVATTO Thermostatic radiator valve (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: TRV - Master Bedroom (0xa4c13835e309ee94): ME167 - AVATTO Thermostatic radiator valve (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: TRV - Dining Room (0xa4c1384c53b556ae): ME167 - AVATTO Thermostatic radiator valve (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: TRV - Living Room (0xa4c1380fa98347a9): ME167 - AVATTO Thermostatic radiator valve (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: TRV - Downstairs Hall (0xa4c13862dcece92a): ME167 - AVATTO Thermostatic radiator valve (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: TRV - Basement (0xa4c1382fadad5122): ME167 - AVATTO Thermostatic radiator valve (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: TRV - Entrance Hall (0xa4c138c3b183e584): ME167 - AVATTO Thermostatic radiator valve (EndDevice)
Zigbee2MQTT:info  2023-11-02 11:32:12: Zigbee: disabling joining new devices.
Zigbee2MQTT:info  2023-11-02 11:32:13: Connecting to MQTT server at mqtt://192.168.86.45:1883
Zigbee2MQTT:debug 2023-11-02 11:32:13: Using MQTT login with username: mqtt-user
Zigbee2MQTT:error 2023-11-02 11:32:15: MQTT error: read ECONNRESET
Zigbee2MQTT:error 2023-11-02 11:32:15: MQTT failed to connect, exiting...
Zigbee2MQTT:info  2023-11-02 11:32:15: Stopping zigbee-herdsman...
Zigbee2MQTT:error 2023-11-02 11:32:16: MQTT error: read ECONNRESET
Zigbee2MQTT:error 2023-11-02 11:32:17: MQTT error: read ECONNRESET
Zigbee2MQTT:error 2023-11-02 11:32:18: MQTT error: read ECONNRESET
Zigbee2MQTT:error 2023-11-02 11:32:20: MQTT error: read ECONNRESET
Zigbee2MQTT:error 2023-11-02 11:32:21: MQTT error: read ECONNRESET
Zigbee2MQTT:error 2023-11-02 11:32:22: MQTT error: read ECONNRESET
Zigbee2MQTT:error 2023-11-02 11:32:23: MQTT error: read ECONNRESET
Zigbee2MQTT:info  2023-11-02 11:32:23: Stopped zigbee-herdsman
It’s complaining it can’t connect to MQTT.
Restart your MQTT broker. Or determine why it’s not accepting connections.
Thanks for the quick response.
I did try restating Mosquitto Broker. It seems that the upgrade of the Mosquitto Broker from 6.2.1 to 6.3.1 is the problem.
It isn’t obvious to me how to install an earlier version. I uninstalled 6.3.1 but I cannot see how to select 6.2.1 for the new install. Any ideas?
After reinstalling 6.3.1 I tried to enter the user ID and password I used with 6.2.1, but this failed when I saved the configuration in the UI and noticed a small message under the config screen that since I am running Mosquitto Broker on the HA hardware that I do not need to specify a username and password.
So I just tried starting Mosquitto Broker and it worked perfectly!!
