I got HO, MQTT and Zigbee2MQTT talking together (I think), I managed to pair a water leak sensor to z2m, in home assistant mqtt integration I see 1 device which is the z2m device, and if in that device I go to mqtt info ->zigbee2mqtt/bridge/info I can see the name I gave the sensor devices:
‘0xa4c13826a86696c8’:
friendly_name: leak 01
But I cant get HA to add it to my devices, from what I can tell all 3 are talking together and HA is receiving the info of the devices paired to z2m, but its no adding them, is it a topic problem? how can I fix it?
z2m conf
mqtt:
server: mqtt://127.0.0.1:1883
discovery_topic: homeassistant
enabled: false
experimental_event_entities: false
keepalive: 60
legacy_action_sensor: false
reject_unauthorized: false
status_topic: homeassistant/status
version: 4
serial:
port: /dev/ttyUSB0
adapter: ember
frontend:
enabled: true
port: 8090
host: 0.0.0.0
version: 4
devices:
'0xa4c13826a86696c8':
Mosquitto conf
allow_anonymous true
# Configure listener to allow remote access
listener 1883
bind_address 0.0.0.0 # Allows connections from any network interface
# Optional: For WebSocket support
listener 9001
protocol websockets
