Zigbee2MQTT problem after HA system updates
I’ve been using HA for 2 years now and have had my share of problems with zigbee sensors dropping off intermittently but managed to solve these problems to the point that I would say my installation is stable.
There is one thing though that I haven’t managed yet, hence this post. In about 50% of the times I perform a system update (HA Core and OS) Zigbee2MQTT replaces the correct port information for my Zigbee USB dongle (SONOFF-ZB-USB-E). This renders the addon to fail. I don’t have these problems when restarting Home Assistant, it seems to only occur after updates. Does anybody recognize this problem and is there a solution?
Check the configuration.yaml in the zigbee2mqtt folder if the wrong port is listed there.
Thanks for the fast reply. I looked in that file which indeed had the wrong port information. I corrected it and hopefully this won’t happen again.
Thanks for the help
