Finally I’ve managed to flash my Sonoff Zigbee 3.0 USB Dongle. Unfortunately when setting op Zigbee2mqtt I’m again struggling a lot. In the log file of zigbee2mqtt I’m constantly getting this error:
> [email protected] start
> node index.js
Zigbee2MQTT:info 2022-06-02 19:08:34: Logging to console and directory: '/config/zigbee2mqtt/log/2022-06-02.19-08-34' filename: log.txt
Zigbee2MQTT:info 2022-06-02 19:08:34: Starting Zigbee2MQTT version 1.25.2 (commit #unknown)
Zigbee2MQTT:info 2022-06-02 19:08:34: Starting zigbee-herdsman (0.14.34)
Zigbee2MQTT:error 2022-06-02 19:08:50: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-06-02 19:08:50: Failed to start zigbee
Zigbee2MQTT:error 2022-06-02 19:08:50: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-06-02 19:08:50: Exiting...
Zigbee2MQTT:error 2022-06-02 19:08:50: Error: SRSP - SYS - getExtAddr after 6000ms
at Timeout._onTimeout (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
at listOnTimeout (node:internal/timers:559:17)
at processTimers (node:internal/timers:502:7)
[19:08:52] INFO: Handing over control to Zigbee2mqtt Core ...
> node index.js
Zigbee2MQTT:info 2022-06-02 19:08:58: Logging to console and directory: '/config/zigbee2mqtt/log/2022-06-02.19-08-58' filename: log.txt
Zigbee2MQTT:info 2022-06-02 19:08:58: Starting Zigbee2MQTT version 1.25.2 (commit #unknown)
Zigbee2MQTT:info 2022-06-02 19:08:58: Starting zigbee-herdsman (0.14.34)
I’ve already checked the wiki of zigbeem2qtt. From there I’ve already checked the USB port, which seems fine. Also flashed to device again, which did not help. Restarted everything like 100 times, but still no difference.
I am having a similar problem if not the same, I have mosquitto broker working but I struggle to set up zigbee2mqtt.
Here is my log, any help is appreciated.
[15:08:36] INFO: Handing over control to Zigbee2mqtt Core ...
> node index.js
Zigbee2MQTT:info 2022-06-13 15:08:43: Logging to console and directory: '/config/zigbee2mqtt/log/2022-06-13.15-08-43' filename: log.txt
Zigbee2MQTT:info 2022-06-13 15:08:43: Starting Zigbee2MQTT version 1.25.2 (commit #unknown)
Zigbee2MQTT:info 2022-06-13 15:08:43: Starting zigbee-herdsman (0.14.34)
Zigbee2MQTT:error 2022-06-13 15:09:03: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-06-13 15:09:03: Failed to start zigbee
Zigbee2MQTT:error 2022-06-13 15:09:03: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-06-13 15:09:03: Exiting...
Zigbee2MQTT:error 2022-06-13 15:09:04: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:102:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:123:29)
at Zigbee.start (/app/lib/zigbee.ts:58:27)
at Controller.start (/app/lib/controller.ts:101:27)
at start (/app/index.js:109:5)
I also ran the command you asked for and the port I have on my configuration.yaml is 8099
I finally managed to solve the problem with the device. I had some problems with ZHA as you mentioned. I just uninstalled ZHA and everything worked flawlesly.
Just to answer you and put more context on the thread:
I flashed myself the sonoff dongle but he process was correct.
Regarding the port I have no clue. I did not select any port.
