Zigbee2MQTT scene change attributes not set in the scene
I have some Tuya bulbs TS0505B_1_1 that I have added to a group in Z2M. When I configure a scene to change brightness and state, all of these lights also change the color_temp attribute to “cool” (which is the standard setting).
My other from eWeLink do not have this behaivour? Can I set Z2M somehow to only change the brightness and state attribute in a scene? I never want to change color temperature, it should be set where I left it. I suspect this is due to buggy firmware of the bulbs but are there any workaround for getting this to work? I have tried to add scenes directly in Home Assistant but then I had problems with Zigbee network congestion. Can I do the same in HA to only publish certain attributes of the bulbs when configuring a scene?
