Zigbee2mqtt: show the networkmap in home assistant
I was looking for a simple solution to display the network map of zigbee2mqtt in hassio without the need of graphviz.
I found the great project viz.js and decided to write a simple custom_component with a service that updates and creates the corresponding files in my www folder.
Important: you have to clear the browsercache after each update
Instructions
  1. Download or clone https://github.com/rgruebel/ha_zigbee2mqtt_networkmap
  2. Copy “custom_components/zigbee2mqtt_networkmap” and content to your “custom_components” folder.
  3. Add the following to your configuration.yaml. It is possible to update the map directly via button. If you want to use this functionality you also have to activate the webhook component
     webhook:
     zigbee2mqtt_networkmap:
     panel_iframe:
       networkmap:
         title: 'Zigbee Map'
         url: '/local/community/zigbee2mqtt_networkmap/map.html'
         icon: 'mdi:graphql'
    You can set the graphviz engine via URL Parameter:
    map.html?engine=circo (Default: dot, Supported Engines)
  4. Restart Homeassistant
  5. Call the service “zigbee2mqtt_networkmap.update”
  6. Test if everything is working
Now you should create an automation which calls the service “zigbee2mqtt_networkmap.update” for example every 10 minutes:
  - id: update_networkmap
    alias: 'Zigbee Map aktualisieren'
    hide_entity: true
      platform: time_pattern
      minutes: '/10'
      seconds: 00
      service: zigbee2mqtt_networkmap.update
very nice! this can really helpfull to optimise and watch the network.
Please do!
Yes please .
Awsome! Please do
Ok, I’ll upload it tomorrow noon. :slight_smile:
i had some time left and added the instructions in the first post.
Let me know if it’s described clearly enough.
Works for me, although as I’m hosting and accessing hass on two different urls depending on where im accessing from the map only works from one of them.
Going to take a look and see if I can modify your script to call a docker container for graphviz (https://hub.docker.com/r/omerio/graphviz-server/), save that to a local file and use a local camera to show it
Works perfectly on my non HASS.io setup. :+1:
cant get it up an running on my hassio :frowning:
actually i noticed, that non of my custom components got loaded during server start :thinking:
@Robin you can use a relative path for the iframe source which makes it work better if your accessing from multiple locations
panel_iframe:
 networkmap:
   title: 'Zigbee Map'
   url: '/local/zigbee2mqtt_networkmap/map.html'
   icon: 'mdi:graphql'
I just found out that, too :slight_smile:
I changed it in the first post.
Thanks a lot.
Works like a charm.
I used a weblink in lovelace instead and added it to a card
entities:
  - entity: sensor.bridge_state
  - entity: switch.zigbee2mqtt_main_join
  - entity: script.1546680345586
    name: Zigbee2Mqtt NetworkMap Update
    icon: 'mdi:graphql'
  - type: weblink
    icon: 'mdi:graphql'
    url: /local/zigbee2mqtt_networkmap/map.html
title: Zigbee2Mqtt
type: entities
Does this mean there must be a new “custom_components” folder in the custom_components folder?
Like this
custom_components/custom_components/zigbee2mqtt_networkmap.py
and the same for www like this:
www/www/zigbee2mqtt_networkmap
No, use only the existing folders
I’m having the same issue.
I’m using 3 other custom components with no problem, so I understand the general idea of where to put them.
Never mind. User error :slight_smile:
Perhaps a little improvement in the map.html file!?
  svg=document.body.appendChild(element);
  svg.style.width = "100%";
Besides the scaling i like this component very much!!
Another suggestion (as a laymen) would be the possibility of other layout engines, if that’s even the proper term.
My only real experience with Graphviz is this website. It looks like the network map it produces here is what that site calls the “dot” engine, while the “circo” engine provides a clearer (although more spread out) representation of the network in my opinion.
Feel free to ignore the suggestion though lol.
Yeah, scaling bothers me, too. I have already found the following project that I might want to integrate:
svg-pan-zoom
Example: http://ariutta.github.io/svg-pan-zoom/demo/inline.html
@Silicon_Avatar: i think the mentioned page uses the same library, so it shouldn’t be a problem
@Silicon_Avatar where was the problem? Maybe i did the same, i am still Not able to get it running :sweat:
