Zigbee2mqtt ssl config
Hello there;
I am getting the following error in the zigbee2mqtt log record installed on Home Assistant. The 172.30.33.3 ip address specified here does not belong to me, I use the ssl side with a dns record over my own domain name and the ssl side is completely healthy. My problem is how can I change my own domain name instead of 172.30.33.3 ip address in zigbee2mqtt module.
configuration:
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: false
permit_join: true
mqtt:
  base_topic: zigbee2mqtt
  server: mqtts://localhost:8883
  user: mqtt_user
  password: '25278146'
serial:
  port: /dev/ttyUSB0
  disable_led: false
  adapter: zstack
advanced:
  log_level: debug
  pan_id: 6754
  channel: 11
  network_key:
    - 1
    - 3
    - 5
    - 7
    - 9
    - 11
    - 13
    - 15
    - 0
    - 2
    - 4
    - 6
    - 8
    - 10
    - 12
    - 13
  availability_blocklist: []
  availability_passlist: []
  rtscts: false
  baudrate: 115200
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
  port: 8099
  host: 'domain'
experimental: {}
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: '-d -d'
  log: true
Error:
21-10-15 03:37:42 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.3:8099 ssl:default [Connect call failed ('172.30.33.3', 8099)]
That is part of the docker network.
Why use and your own domain and ingress ? Choose one of the two.
Because I can connect via ssl and use it with domain name in both local or remote connection. Thus, when the phone switches to wifi or cellular, there is no disconnection etc., it works more quickly.
This 172… ip is not accessible Could this 172… ip home assistant have a connection to the cloud?
I remember that when I made the first ssl settings, it was automatically redirected to this ip, then I overcame it with the following code in the configuration.yaml file.
homeassistant:
  external_url: "https://domain.com:8123"
  internal_url: "https://domain.com:8123"
  legacy_templates: false
http:
  base_url: "https://domain.com:8123"
If you use ingress, you connect to the zigbee2mqtt interface using the HA domain. No need for an extra domain.
I made a fix but I still get the same error.
Config file:
homeassistant:
  external_url: "https://domain.com.tr:8123"
  internal_url: "https://domain.com.tr:8123"
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
http:
  base_url: "https://domain.com.tr:8123"
  server_port: 8123
  ssl_certificate: /ssl/origin.pem
  ssl_key: /ssl/privkey.pem
  use_x_forwarded_for: true
  trusted_proxies:
    # Add the Cloudflare IPs as trusted proxies https://www.cloudflare.com/ips-v4
    - 173.245.48.0/20
    - 103.21.244.0/22
    - 103.22.200.0/22
    - 103.31.4.0/22
    - 141.101.64.0/18
    - 108.162.192.0/18
    - 190.93.240.0/20
    - 188.114.96.0/20
    - 197.234.240.0/22
    - 198.41.128.0/17
    - 162.158.0.0/15
    - 104.16.0.0/13
    - 104.24.0.0/14
    - 172.64.0.0/13
    - 131.0.72.0/22
frontend:
  themes: !include_dir_merge_named themes
media_player:
  - platform: androidtv
    host: 192.168.1.69
alarm_control_panel:
  - platform: manual
    code: !secret alarm_code
    arming_time: 30
    delay_time: 45
logger:
  default: warning
  logs:
    custom_components.bosch: debug
    bosch_thermostat_client: debug
