Hi all,
Need some help as Zigbee2mqtt stopped working overnight and won’t start anymore.
Some context:
I’m moving from conbee ii on a RPI to Sonoff Dongle E (flashed with: ncp-uart-hw-v7.4.4.0-zbdonglee-115200.gbl) on a Proxmox VM with HA core (2025.4.3).
The new VM with Sonoff is running with a new Zigbee network with a different channel for some weeks without issues.
Yesterday I started moving devices to the ‘Sonoff network’, from 4 devices to about 25.
So far so good. Everything works
During the night it started with these errors (sensor values appear in HA up to this time and before this time only info related messages):
[2025-04-21 01:01:37] [31merror [39m: zh:ember:ezsp: ERROR Transaction failure; status=ASH_ERROR_TIMEOUTS. Last Frame: [FRAME: ID=52:"SEND_UNICAST" Seq=148 Len=7].
[2025-04-21 01:01:37] [31merror [39m: zh:ember: Adapter fatal error: ASH_ERROR_TIMEOUTS
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: ASH COUNTERS since last clear:
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: Total frames: RX=1216, TX=1483
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: Cancelled : RX=0, TX=0
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: DATA frames : RX=1209, TX=267
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: DATA bytes : RX=30399, TX=7462
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: Retry frames: RX=7, TX=0
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: ACK frames : RX=0, TX=1216
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: NAK frames : RX=0, TX=0
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: nRdy frames : RX=0, TX=0
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: CRC errors : RX=0
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: Comm errors : RX=0
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: Length < minimum: RX=0
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: Length > maximum: RX=0
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: Bad controls : RX=0
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: Bad lengths : RX=0
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: Bad ACK numbers : RX=0
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: Out of buffers : RX=0
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: Retry dupes : RX=7
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: Out of sequence : RX=0
[2025-04-21 01:01:37] [32minfo [39m: zh:ember:uart:ash: ACK timeouts : RX=0
[2025-04-21 01:01:37] [31merror [39m: zh:ember:ezsp: ERROR Transaction failure; status=NOT_CONNECTED. Last Frame: [FRAME: ID=52:"SEND_UNICAST" Seq=148 Len=7].
[2025-04-21 01:02:07] [32minfo [39m: zh:ember:uart:ash: Port closed.
[2025-04-21 01:02:07] [32minfo [39m: zh:ember:uart:ash: ======== ASH stopped ========
[2025-04-21 01:02:07] [32minfo [39m: zh:ember:ezsp: ======== EZSP stopped ========
[2025-04-21 01:02:07] [32minfo [39m: zh:ember: ======== Ember Adapter Stopped ========
[2025-04-21 01:02:07] [31merror [39m: z2m: Adapter disconnected, stopping
[2025-04-21 01:02:07] [32minfo [39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"offline"}'
[2025-04-21 01:02:07] [32minfo [39m: z2m: Disconnecting from MQTT server
[2025-04-21 01:02:07] [32minfo [39m: z2m: Stopping zigbee-herdsman...
[2025-04-21 01:02:07] [32minfo [39m: z2m: Stopped zigbee-herdsman
[2025-04-21 01:02:07] [32minfo [39m: z2m: Stopped Zigbee2MQTT
(I have watchdog off for now to notice if there would be issues).
Every time when I restart zigbee2mqtt I get these errors:
[2025-04-21 07:23:21] info: zh:ember: Using default stack config.
[2025-04-21 07:23:21] info: zh:ember: ======== Ember Adapter Starting ========
[2025-04-21 07:23:21] info: zh:ember:ezsp: ======== EZSP starting ========
[2025-04-21 07:23:21] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-04-21 07:23:21] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2025-04-21 07:23:21] info: zh:ember:uart:ash: Serial port opened
[2025-04-21 07:23:21] info: zh:ember:uart:ash: ======== ASH starting ========
[2025-04-21 07:23:24] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-04-21 07:23:24] info: zh:ember:uart:ash: ======== ASH starting ========
[2025-04-21 07:23:26] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-04-21 07:23:26] info: zh:ember:uart:ash: ======== ASH starting ========
[2025-04-21 07:23:29] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-04-21 07:23:29] info: zh:ember:uart:ash: ======== ASH starting ========
[2025-04-21 07:23:31] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-04-21 07:23:31] info: zh:ember:uart:ash: ======== ASH starting ========
[2025-04-21 07:23:34] error: z2m: Error while starting zigbee-herdsman
[2025-04-21 07:23:34] error: z2m: Failed to start zigbee-herdsman
[2025-04-21 07:23:34] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-04-21 07:23:34] error: z2m: Exiting...
[2025-04-21 07:23:34] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:672:19)
at EmberAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1538:24)
at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:136:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:104:13)
- What does the HOST_FATAL_ERROR mean? Is that related to the mosquitto host (core-mosquitto)? or communication to/from the Sonoff adapter, something else?
Restarted several times (restart zigbee2mqtt, restart HA, restart VM), the error stays. I did not change anything while sleeping!
The configuration.yaml:
version: 4
mqtt:
base_topic: zigbee2mqtt
server: mqtt://core-mosquitto:1883
user: addons
password: xxxxx
keepalive: 60
reject_unauthorized: true
version: 4
serial:
port: /dev/ttyUSB0
adapter: ember
baudrate: 115200
rtscts: false
advanced:
log_level: info
channel: 25
network_key:
- [16 lines with numbers]
pan_id: xxxxx
ext_pan_id:
- [8 lines with numbers]
frontend:
enabled: true
port: 8099
homeassistant:
enabled: true
devices:
[devices after this line]
Mosquitto is running fine and receives messages from several other non-zigbee mqtt devices.
I tried the config also with:
port: >-
/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_c84c4fc1d112ef11bca275b8bf9df066-if00-port0
user: mosquitto
password: [the password]
No difference.
In the zigbee2mqtt configuration tab of the addon the mqtt and serial sections where empty.
I added to test this morning:
mqtt:
user: mosquitto
password: [password]
- I understand that Herdsman errors are related to mqtt communication but do not see what changed/went wrong.
- Is something scheduled at 01:00 hours for zigbee2mqtt?
- I really do not understand what I am doing wrong. Can someone point me into the right direction? Thanks!
