Zigbee2MQTT stops after updating to version 2.1.0
Everything works fine until updating to Zigbee2MQTT version 2.1.0 it stops working. I’m using SMLight SLZB-06P zigbee dongle
Error log:
2025-02-04 00:16:17] info: z2m: Starting Zigbee2MQTT version 2.1.0 (commit #unknown)
[2025-02-04 00:16:17] info: z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-04 00:16:17] info: zh:zstack:znp: Opening TCP socket with slzb-06p7.local:6638
[2025-02-04 00:16:17] info: zh:zstack:znp: Socket connected
[2025-02-04 00:16:17] info: zh:zstack:znp: Socket ready
[2025-02-04 00:16:17] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-02-04 00:16:18] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-02-04 00:16:36] error: z2m: Error while starting zigbee-herdsman
[2025-02-04 00:16:36] error: z2m: Failed to start zigbee-herdsman
[2025-02-04 00:16:36] error: z2m: Check Zigbee2MQTT fails to start/crashes runtime | Zigbee2MQTT for possible solutions
[2025-02-04 00:16:36] error: z2m: Exiting…
[2025-02-04 00:16:36] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
There are a ton of posts about the update last month.
If you re still catching up from that, do a search here and that should help.
There is also the Z2M discord:
