Has anyone ever encountered an issue where after upgrading to zigbee2mqtt v2.13.0-1, devices stop updating with the latest status in the dashboard?
I have a smart plug that controls a water pump for a hydroponics tower. There’s an automation that turns it on every 0th minute and then turns it off again at the 15th minute. After the zigbee2mqtt update, it works fine but after a while, I noticed that switch.balcony_water_pump.state remains On but the switch has actually been turned off. When this happens, it’s not only this particular switch but all zigbee devices fail to update.
I didn’t have the time to properly troubleshoot as I needed it to work immediately. Quickest way to fix it was to just revert it back to v2.12.1-1.
