Hi everyone, which adapter would you recommend for zigbee2mqtt
I would also like to use an additional antenna.
https://www.mouser.ch/new/texas-instruments/ti-cc253x-dev-tools/
https://www.zigbee2mqtt.io/information/supported_adapters.html
Depends on your budget.
The LAUNCHXL-CC26X2R1 and LAUNCHXL-CC1352P-2 are way more better then the CC2531 or CC2530, but also way more expensive.
Money is no object to me. What is important is that it works … otherwise I have to buy 2 times, which does not help. I assume that the CC26X2R1 must be flashed as well, right?
what do you think of deconz with a conbee 2
They all need to be flashed. I have no experience with deconz.
Is there a nice case available for these?
There´s a link in the zigbee2mqtt site
I recently ordered CC1352P-2, I did get it working easily according to instructions.
Don´t have an external antenna yet and just testing with a couple of devices.
Managed to 3D-print the case also and board fits nicely in it - though I have concerns about
if and when the board heats up in the use
I tried the conbee 2 and it didn´t work for me
