Hi everyone,
I’m a complete beginner with Home Assistant, Zigbee, and related topics, so I’d really appreciate your help.
I’ve been trying to get Zigbee2MQTT running on Home Assistant, but every time I try to open Zigbee2MQTT, I get an error saying it hasn’t started. When I check the logs of the add-on, I see the errors shown in the attached image.
After some research, I found that issues with version 2.0 are quite common, and I tried editing the configuration.yaml
file to adjust the serial settings. Unfortunately, this hasn’t fixed the problem.
What I’ve Tried:
- Adjusting the serial settings in
configuration.yaml
. - Restarting the add-on and Home Assistant multiple times.
- Ensuring the Zigbee stick is properly connected.
Does anyone have any advice or tips to get this working? Any guidance for a beginner would be really appreciated.
Thanks in advance!
