Zigbee2MQTT won't connect. Please help!
I just moved from a pi to HAOS on a virtual machine. For some reason I can’t get z2m to start.
[15:52:19] INFO: Preparing to start...
[15:52:19] INFO: Socat not enabled
[15:52:19] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:error 2024-01-24 15:52:31: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-01-24 15:52:31: Failed to start zigbee
Zigbee2MQTT:error 2024-01-24 15:52:31: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-01-24 15:52:31: Exiting...
Zigbee2MQTT:error 2024-01-24 15:52:31: undefined
I’ve tried everything in the site is says to go to that applies to HAOS.
Config:
serial
  port: /dev/ttyACM0
  adapter: deconz
It just connects and disconnects repeatedly from the machine.
I’ve already enabled the USB port and Serial Port. Neither helped.
Make sure you don’t have the deCONZ add-on running and that ZHA (Zigbee Home Automation) isn’t enabled
I forgot to update. This solved itself, just suddenly worked. Great suggestion though I’d tried that. Thank you.
