Hi all,
I recently received my Sonoff Zigbee dongle and tried installing it in Home assistant, but no luck so far.
I’m using a Supervised installation of Home Assistant on a Synology NAS virtual machine and I gave the VM access to the zigbee stick. Configured it all in Home Assistant, but nothing is happening when starting the Zigbee2MQTT add-on.
[17:10:37] INFO: Preparing to start…
[17:10:37] INFO: Socat not enabled
[17:10:38] INFO: Starting Zigbee2MQTT…
Zigbee2MQTT:info 2022-12-02 17:10:41: Logging to console and directory: ‘/config/zigbee2mqtt/log/2022-12-02.17-10-41’ filename: log.txt
Zigbee2MQTT:info 2022-12-02 17:10:41: Starting Zigbee2MQTT version 1.28.4 (commit #unknown)
Zigbee2MQTT:info 2022-12-02 17:10:41: Starting zigbee-herdsman (0.14.76)
I’m seeing a lot of people having errors when the addon is trying to start zigbee-herdsman, but it looks like my addon is not proceeding for some reason.
Any recommendations to solve this?
Thanks in advance!
Peter
