Zigbee2MQTT - Xiaomi MCCGQ11LM - Battery
Hi Team.
So I purchased a Aqara Door and Window Sensor and i have hooked it up via Zigbee2MQTT. The device has connected but its not showing the battery %
Am i missing something here?
I’ve seen it take a little while for the battery to update. Sometimes pressing the button on the unit helps force it.
Personally, I’m too impatient. I just immediately pair the device again and it usually pops up. You don’t have to delete the device first, just enable “permit join” and press the device button for 5 seconds to enable pairing mode. It should re-interview and update.
Thanks mate. I will try that in bit and see if it resolves it.
Actually that worked exactly as you said. Thanks mate. I’m starting to learn all this little steps with devices.
Really appreciate the reply and help.
