I have 2 sensors that stopped reporting their status via zigbee2mqtt. One is the popular Aqara motion sensor and the other is the Xiaomi temperature sensor. I’ve replaced the batteries, enabled pairing mode in z2m and both devices pretended a successful connection (blinked with light signalling a successful connection). But they do not report anything via z2m. The status is still the old one. I’ve force-removed one of the devices, and it doesn’t even show up again on the z2m list.
Any idea where can I verify if they actually connect, or how can I re-add them? Maybe I should change something in the config manually?
Did you find a solution for your problem? I have the same issue…
