Ziggo Modem integration (DOCSIS signal monitoring & diagnostics)
Ziggo Modem integration (DOCSIS monitoring & diagnostics)
I’ve created a custom Home Assistant integration for monitoring Ziggo cable modems (Sagemcom).
This integration uses the modem’s local API and provides detailed insight into signal quality, connection health and DOCSIS metrics — fully local, no cloud required.
:sparkles: Features
  • Modem status & uptime
  • Downstream signal analysis (power, SNR, channels)
  • Upstream monitoring (power, timeouts)
  • Error tracking (SC-QAM & OFDM)
  • Speed profile detection (download / upload in Mbit/s)
  • Cable quality classification
  • Binary sensors for connectivity issues
:wrench: Controls
  • Integration pause
  • Session release (useful when UI login is blocked)
  • Modem reboot
:bar_chart: What you get
  • Clear overview of DOCSIS signal quality
  • Detection of cable issues
  • Monitoring of upstream timeouts
  • Insight into your actual provisioned speed profile
:warning: Notes
  • Works only locally (default modem IP: 192.168.100.1)
  • Designed for Ziggo Sagemcom modems
  • Uses undocumented API (may change with firmware updates)
:package: Installation
HACS (recommended)
  1. Add this repository as a custom repository
  2. Select category: Integration
  3. Install
  4. Restart Home Assistant
Repository
:light_bulb: Feedback
Feel free to test it and report issues or suggestions!
:hot_beverage: Support
If you find this useful, consider supporting development (link in README)
First release, feedback is welcome :+1:
Hi, looks like some sensors are reversed, when mij internet connection is gone some parameters say : GOOD en when I have a good connection some others/same say : BAD, no connection etc etc. Very weird !!
