ZMEEUZBB USB Stick on NUC7i3BNK
Hi, I have successfully installed HASS OS (core-2021.3.4 , supervisor-2021.03.6) on my NUC.
Now I’m working on Z WAVE integration. All Videos I found explain it with RP4.
My biggest hurdle is the very exhaustive output on Supervisor/System/Hardware. It shows more than 1500 lines.
To see the impact of connection the USB Stick to USB front port (blue) added the lines below to
the output. There is no clear text which tells me that the Stick is a ZWAVE.ME USB Stick.
So my questions are:
Did I make the hardware report request correctly?
What info (out of the added lines) do I have to put in the config.yaml ?
Hope someone can help on this.
      SUBSYSTEM: usbmon
  - name: 1-2
    sysfs: '/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2'
    dev_path: /dev/bus/usb/001/005
    subsystem: usb
    by_id: null
    attributes:
      BUSNUM: '001'
      DEVNAME: /dev/bus/usb/001/005
      DEVNUM: '005'
      DEVPATH: '/devices/pci0000:00/0000:00:14.0/usb1/1-2'
      DEVTYPE: usb_device
      DRIVER: usb
      ID_BUS: usb
      ID_MODEL: '0200'
      ID_MODEL_ENC: '0200'
      ID_MODEL_ID: '0200'
      ID_PATH: 'pci-0000:00:14.0-usb-0:2'
      ID_PATH_TAG: pci-0000_00_14_0-usb-0_2
      ID_REVISION: '0000'
      ID_SERIAL: 0658_0200
      ID_USB_INTERFACES: ':020201:0a0000:'
      ID_VENDOR: 0658
      ID_VENDOR_ENC: 0658
      ID_VENDOR_ID: 0658
      MAJOR: '189'
      MINOR: '4'
      PRODUCT: 658/200/0
      SUBSYSTEM: usb
      TYPE: 2/0/0
      USEC_INITIALIZED: '2771171408'
  - name: ttyACM0
    sysfs: '/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/tty/ttyACM0'
    dev_path: /dev/ttyACM0
    subsystem: tty
    by_id: /dev/serial/by-id/usb-0658_0200-if00
    attributes:
      DEVLINKS: >-
        /dev/serial/by-path/pci-0000:00:14.0-usb-0:2:1.0
      DEVNAME: /dev/ttyACM0
      DEVPATH: '/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/tty/ttyACM0'
      ID_BUS: usb
      ID_MODEL: '0200'
      ID_MODEL_ID: '0200'
      ID_PATH: 'pci-0000:00:14.0-usb-0:2:1.0'
      ID_PATH_TAG: pci-0000_00_14_0-usb-0_2_1_0
      ID_REVISION: '0000'
      ID_TYPE: generic
      ID_USB_DRIVER: cdc_acm
      ID_USB_INTERFACE_NUM: '00'
      ID_VENDOR: 0658
      ID_VENDOR_ENC: 0658
      ID_VENDOR_ID: 0658
      MAJOR: '166'
      MINOR: '0'
      SUBSYSTEM: tty
      TAGS: ':systemd:'
      USEC_INITIALIZED: '2771174966'
Or /dev/ttyACM0 will also work
Take note that configuration through config.yaml will use the legacy Z-Wave integration, the way forward would be to use Z-WaveJS through the Integrations page.
Z-Wave (deprecated) - Home Assistant (home-assistant.io)
Z-Wave JS - Home Assistant (home-assistant.io)
Rick, thanks a lot.
I have now integrated the Z-WAVE JS.
How can I check that is was correctly done? I don’t see any changes in the config.yaml.
However, it looks like that I could successfully pair and remove my fibaro smoke sensor.
If you can pair and remove your devices you should be good to go :slight_smile:
The integrations are not part of the config.yaml, really unsure where it will be saved.
