Why would I see this “Failed to setup” error running Z-Wave JS add-on when all devices are working properly?
I’m not running the Z-wave JS UI add-on at this point but have in the past. When running that add-on and not running the JS add-on there were times when the JS-UI add-on would update and I would see this issue and devices were not working.
Today it appears we no longer need the JS UI add-on to take advantage of LR.
I ran into a similar issue a couple of days ago.
-HA OS virtually on UTM with two USB devices mounted on startup
- ZooZ : 800 Z-wave stick, firmware 1.5
- Insteon Modem : FT 232R USB UART
I have occasionally run into issues when restarting the VM, where the USB devices do not mount, but a couple of full and safe restarts would correct the issue. I place this issue with the UTM app and startup sequence, not with HA.
After updating
- HA OS 15.0 → 15.1
- HA Core 2025.6.3 → 2025.7
I received the same error ‘failed to setup’ z-wave after every restart.
I investigated. The first oddity I found was the /dev/serial folder was no longer there. A serious problem from my perspective since the integrations refer to these ‘aliases’ ( for lack of a better word) as shown in the log files.
Digging further, I then found the Z-Wave USB device on the VM was being named something different from the past. It used to be descriptive and simple ‘800 Z-Wave Stick’ and now it was being named something like ‘Device-blah-something2:’ ( I did not record what it was) . This was preventing my startup script from mounting the Z-wave USB auto-mount on startup due to the hard coded name in my scripting.
I attempted to reconfigure the current controller ( Z-Wave) and select the ‘newly named’ USB device within the Zwave integration AND the Zwave JS add-on. It would not work and the ZWave USB device would not connect.
I reverted both HA OS & Core and am now operational.
Posted too early regarding reversion. Same issues happening with earlier versions of HA Core and OS.
It seems the Zooz Z-wave stick flaking out. Name changes and unmounting on it’s own. I have no issues with the Insteon Modem and moving devices around on various USB ports yields the same flakiness with the Zooz Z-wave stick.
After a few iterations of various version installs of HA Core, HA OS and Z-Wave JS. I finally have a stable setup. Had to roll back to Z-Wave JS v.0.15
my config
Mac OS 15.5
UTM 4.6.5
HA OS 15.2
HA Core 2025.7.1 Z-Wave JS 0.15 (0.16 & 0.17 were not able to maintain a steady USB connect with the Z-Wave USB stick)
ZST39 LR by Zooz Firmware: 1.50
The issue turned out to be some sort of corruption with my Z-Wave JS install / config files. I did not find any other online reports of issues with Z-Wave JS and versioning and the system flaked out every time when starting Z-Wave JS addon.
I have 22 Z-Wave devices. I disabled and uninstalled (with all data deletion) Z-Wave JS from HA, both integration and add on. Restarted HA and VM a couple of times.
Reinstalled Z-Wave JS and got a stable system. I had to factory reset five devices, but did not have to recreate from scratch, since the z-wave devices were recreated in HA.
The issue turned out to be some sort of corruption with my Z-Wave JS install / config files. I did not find any other reports of issues with Z-Wave JS and the system flaked out every time when starting Z-Wave JS addon.
I have 22 Z-Wave devices. I disabled and uninstalled the Z-Wave JS from HA, both integration and add on. Restarted HA and VM a couple of times.
Reinstalled Z-Wave JS and got a stable system. I had to factory reset five devices.
