I have pasted the updated zwcfg commands for the scene portion of the Zen22 but i cannot seem to get the scene to activate. I’ve been banging my head against the wall for the past month trying to figure this out. thanks ahead for any help you can provide.
Below are the logs from OZW_Log.txt after i double click:
2020-09-04 23:45:37.145 Info, Node002, Received SwitchMultiLevel report: level=99
2020-09-04 23:45:37.145 Detail, Node002, Refreshed Value: old value=99, new value=99, type=byte
2020-09-04 23:45:37.145 Detail, Node002, Changes to this value are not verified
2020-09-04 23:45:37.145 Detail, Node002, Notification: ValueChanged
2020-09-04 23:45:37.170 Detail, Node002, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x02, 0x05, 0x26, 0x03, 0x63, 0x63, 0x00, 0xd2
2020-09-04 23:45:37.170 Info, Node002, Received SwitchMultiLevel report: level=99
2020-09-04 23:45:37.170 Detail, Node002, Refreshed Value: old value=99, new value=99, type=byte
2020-09-04 23:45:37.170 Detail, Node002, Changes to this value are not verified
2020-09-04 23:45:37.170 Detail, Node002, Notification: ValueChanged
I’ve contacted zooz and after some debugging they have not been able to help me.
Below is also the zwcfg settings:
<?xml version="1.0" encoding="utf-8" ?>
<Driver xmlns="http://code.google.com/p/open-zwave/" version="3" home_id="0xf24e0543" node_id="1" api_capabilities="0" controller_capabilities="8" poll_interval="60000" poll_interval_between="true">
<Node id="1" name="" location="" basic="2" generic="2" specific="1" type="Static PC Controller" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="0" name="Z-Wave (Sigma Designs)">
<Product type="1" id="1" name="UZB Z-Wave USB Adapter" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" after_mark="true">
<Instance index="1" />
<Value type="byte" genre="basic" instance="1" index="0" label="Basic" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
</CommandClass>
</CommandClasses>
</Node>
<Node id="2" name="" location="" basic="4" generic="17" specific="1" roletype="5" devicetype="1540" nodetype="0" type="Multilevel Power Switch" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="27a" name="Zooz">
<Product type="b112" id="1f1c" name="ZEN22 Dimmer V2" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4" mapping="38">
</CommandClass>
<CommandClass id="38" name="COMMAND_CLASS_SWITCH_MULTILEVEL" version="4" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="button" genre="user" instance="1" index="1" label="Bright" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="button" genre="user" instance="1" index="2" label="Dim" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="bool" genre="system" instance="1" index="3" label="Ignore Start Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
<Value type="byte" genre="system" instance="1" index="4" label="Start Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
</CommandClass>
<CommandClass id="39" name="COMMAND_CLASS_SWITCH_ALL" version="1" request_flags="4">
<Value type="list" genre="system" instance="1" index="0" label="Switch All" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Disabled" value="0" />
<Item label="Off Enabled" value="1" />
<Item label="On Enabled" value="2" />
<Item label="On and Off Enabled" value="255" />
</Value>
</CommandClass>
<CommandClass id="90" name="COMMAND_CLASS_DEVICE_RESET_LOCALLY" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="91" name="COMMAND_CLASS_CENTRAL_SCENE" version="1" request_flags="4" innif="true" scenecount="0">
<Value type="int" genre="system" instance="1" index="0" label="Scene Count" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="2" />
<Value type="int" genre="user" instance="1" index="1" label="Bottom Button Scene" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="3" />
<Value type="int" genre="user" instance="1" index="2" label="Top Button Scene" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="3" />
</CommandClass>
<CommandClass id="94" name="COMMAND_CLASS_ZWAVEPLUS_INFO" version="1" request_flags="4" innif="true">
<Value type="byte" genre="system" instance="1" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
<Value type="short" genre="system" instance="1" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="1536" />
<Value type="short" genre="system" instance="1" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="1540" />
</CommandClass>
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1">
<Value type="list" genre="config" instance="1" index="1" label="Paddle Control" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2" vindex="0" size="1">
<Help>Controls the on/off orientation of the rocker switch</Help>
<Item label="Upper paddle turns on" value="0" />
<Item label="Upper paddle turns off" value="1" />
<Item label="Both paddles toggle" value="2" />
</Value>
<Value type="list" genre="config" instance="1" index="2" label="LED Indicator Control" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="3" vindex="0" size="1">
<Help>Control the LED indicator on switch</Help>
<Item label="LED on when switch is off" value="0" />
<Item label="LED on when switch is on" value="1" />
<Item label="LED is always off" value="2" />
<Item label="LED is always on" value="3" />
</Value>
<Value type="list" genre="config" instance="1" index="3" label="Auto Turn-off Timer" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="0" size="1">
<Help>Use this parameter to enable or disable the auto turn-off timer function</Help>
<Item label="Enabled" value="1" />
</Value>
<Value type="short" genre="config" instance="1" index="4" label="Timer-off Time" units="minutes" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="65535" value="60">
<Help>Use this parameter to set the time after which you want the switch to automatically turn off once it has been turned on. The number entered as value corresponds to the number of minutes</Help>
</Value>
<Value type="list" genre="config" instance="1" index="5" label="Auto Turn-On Timer" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="0" size="1">
</Value>
<Value type="short" genre="config" instance="1" index="6" label="Timer-On Time" units="minutes" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="65535" value="60">
<Help>Use this parameter to set the time after which you want the switch to automatically turn on once it has been turned off. The number entered as value corresponds to the number of minutes</Help>
</Value>
<Value type="list" genre="config" instance="1" index="8" label="On Off Status after Power Failure" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2" vindex="2" size="1">
<Help>Set the on off status for switch after power failure</Help>
<Item label="forced to OFF (regardless of state prior to power outage)" value="0" />
<Item label="forced to ON (regardless of state prior to power outage)" value="1" />
<Item label="remembers and restores on/off status after power failure" value="2" />
</Value>
<Value type="byte" genre="config" instance="1" index="9" label="Ramp Rate Control (Paddle)" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="99" value="1">
<Help>Adjust the ramp rate for your dimmer (fade-in / fade-out effect for on / off operation). Values correspond to the number of seconds it take for the dimmer to reach full brightness or turn off when operated manually</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="10" label="Minimum Brightness" units="percent" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="99" value="1">
<Help>Set the minimum brightness level (in %) for your dimmer. You won’t be able to dim the light below the set value</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="11" label="Maximum Brightness" units="percent" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="99" value="99">
<Help>Set the maximum brightness level (in %) for your dimmer. You won’t be able to add brightness to the light beyond the set value. Note: if Parameter 12 is set to value 0, Parameter 11 is automatically disabled.</Help>
</Value>
<Value type="list" genre="config" instance="1" index="12" label="Brightness on Double Tap" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="0" size="1">
<Help>Choose if you want the dimmer to turn on to full brightness or custom brightness level aer you double-tap the upper paddle</Help>
<Item label="the light will turn on to full brightness with double tap" value="0" />
<Item label="the light will turn on to the maximum brightness level set in Parameter 11 with double tap" value="1" />
</Value>
<Value type="bool" genre="config" instance="1" index="13" label="Enable / Disable Scene Control" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False">
<Help>Enable or disable scene control functionality for quick double tap triggers.</Help>
</Value>
<Value type="list" genre="config" instance="1" index="14" label="Enable / Disable Double Tap" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2" vindex="0" size="1">
<Help>Enable or disable the doubletap function and assign brightness level to single tap</Help>
<Item label="double tap to full / maximum brightness level enabled" value="0" />
<Item label="double tap to full / maximum brightness level disabled, single tap turns light on to last brightness level" value="1" />
<Item label="double tap to full / maximum brightness level disabled, single tap turns light on to full / maximum brightness level" value="2" />
</Value>
<Value type="bool" genre="config" instance="1" index="15" label="Enable / Disable Paddle Control" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True">
<Help>Enable or disable local on/off control. If enabled, you’ll only be able to control the connected light via Z-Wave. Scenes and other functionality will still be available through paddles</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="16" label="Physical Dimming Speed" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="99" value="4">
<Help>Set the time in seconds to get from 0% to 100% brightness when pressing and holding the paddle (physical dimming)</Help>
</Value>
<Value type="list" genre="config" instance="1" index="17" label="Ramp Rate Control (Z-Wave)" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="1" size="1">
<Help>Choose if you want to set the Z-Wave ramp rate independently of the physical (paddle) ramp rate or if you want them to match</Help>
<Item label="Z-Wave ramp rate matches the physical ramp rate set in parameter 9" value="0" />
<Item label="Z-Wave ramp rate is set independently using Z-Wave commands" value="1" />
</Value>
<Value type="byte" genre="config" instance="1" index="18" label="Custom Brightness Level On" units="percent" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="99" value="0">
<Help>Set the custom brightness level (instead of the last set brightness level) you want the dimmer to come on to when you single tap the upper paddle</Help>
</Value>
<Value type="list" genre="config" instance="1" index="19" label="3-Way Switch Type" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2" vindex="0" size="1">
<Help>Choose the type of 3-way switch you want to use with this dimmer in a 3-way set-up</Help>
<Item label="regular mechanical 3-way on/off switch - Z-Wave dimming" value="0" />
<Item label="regular mechanical 3-way on/off switch - paddle dimming" value="1" />
<Item label="momentary switch" value="2" />
</Value>
<Value type="list" genre="config" instance="1" index="20" label="Smart Bulb Mode" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="0" size="1">
<Help>Choose how you'd like the dimmer to report when paddles are tapped and held</Help>
<Item label="report each brightness level to hub when physical / Z-Wave control is disabled" value="0" />
<Item label="report final brightness level only for physical dimming" value="1" />
</Value>
</CommandClass>
<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="115" name="COMMAND_CLASS_POWERLEVEL" version="1" request_flags="4" innif="true">
<Value type="list" genre="system" instance="1" index="0" label="Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Normal" value="0" />
<Item label="-1dB" value="1" />
<Item label="-2dB" value="2" />
<Item label="-3dB" value="3" />
<Item label="-4dB" value="4" />
<Item label="-5dB" value="5" />
<Item label="-6dB" value="6" />
<Item label="-7dB" value="7" />
<Item label="-8dB" value="8" />
<Item label="-9dB" value="9" />
</Value>
<Value type="byte" genre="system" instance="1" index="1" label="Timeout" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="button" genre="system" instance="1" index="2" label="Set Powerlevel" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="byte" genre="system" instance="1" index="3" label="Test Node" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="list" genre="system" instance="1" index="4" label="Test Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
<Value type="short" genre="system" instance="1" index="5" label="Frame Count" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="button" genre="system" instance="1" index="6" label="Test" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="button" genre="system" instance="1" index="7" label="Report" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="list" genre="system" instance="1" index="8" label="Test Status" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Failed" value="0" />
<Item label="Success" value="1" />
<Item label="In Progress" value="2" />
</Value>
<Value type="short" genre="system" instance="1" index="9" label="Acked Frames" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
</CommandClass>
<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="2">
<Associations num_groups="1">
<Group index="1" max_associations="5" label="Lifeline" auto="true" multiInstance="true">
<Node id="1" />
</Group>
<Group index="2" max_associations="5" label="Group 2" auto="false" multiInstance="true" />
<Group index="3" max_associations="5" label="Group 3" auto="false" multiInstance="true" />
</Associations>
</CommandClass>
<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4" innif="true">
<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3" />
<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="5.03" />
<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3.07" />
</CommandClass>
<CommandClass id="142" name="COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION" version="1" request_flags="4" innif="true">
<Associations num_groups="3">
<Node id="1" />
</Group>
</Associations>
</CommandClass>
</CommandClasses>
</Node>
