ZV9001K12-DIM-Z5 (Sunricher 5-channel Z-Wave remote) Blueprint
Made a blueprint for the Sunricher ZV9001K12-DIM-Z5, the 5-channel Z-Wave wall remote. It picks up the Central Scene events so you can hang your own actions on each button.
There are 6 button pairs: the top All On/Off and then 5 dimming groups, each with an on and an off. Every button gives you press, hold and release, so plenty to work with.
I started from the existing Z4 blueprint but the key mapping was off for this one, so I fixed it. On the Z5 the keys just run 001 to 012 straight through: All On/Off is 001/002, then group 2 is 003/004, and so on up to group 6 on 011/012. No separate scene buttons.
Needs Z-Wave JS and the remote paired so it exposes the scene notifications. Just create an automation from the blueprint, pick your remote, and fill in whatever buttons you want to use. Empty ones are ignored.
blueprint:
  description: "Use the ZV9001K12-DIM-Z5 to trigger actions and events. \n"
  domain: automation
  source_url: https://community.home-assistant.io/t/zv9001k12-dim-z5-sunricher-5-channel-z-wave-remote-blueprint/1018758
  input:
    remote_entity:
      description: The ZV9001K12-DIM-Z5 to listen for events on.
      selector:
        device:
          integration: zwave_js
          manufacturer: Sunricher
          model: ZV9001K12-DIM-Z5
    G1_Press_on:
      name: Group 1 (All) press on
      selector:
        action: {}
      default: []
    G1_Press_off:
      name: Group 1 (All) press off
      selector:
        action: {}
      default: []
    G2_Press_on:
      name: Group 2 press on
      selector:
        action: {}
      default: []
    G2_Press_off:
      name: Group 2 press off
      selector:
        action: {}
      default: []
    G3_Press_on:
      name: Group 3 press on
      selector:
        action: {}
      default: []
    G3_Press_off:
      name: Group 3 press off
      selector:
        action: {}
      default: []
    G4_Press_on:
      name: Group 4 press on
      selector:
        action: {}
      default: []
    G4_Press_off:
      name: Group 4 press off
      selector:
        action: {}
      default: []
    G5_Press_on:
      name: Group 5 press on
      selector:
        action: {}
      default: []
    G5_Press_off:
      name: Group 5 press off
      selector:
        action: {}
      default: []
    G6_Press_on:
      name: Group 6 press on
      selector:
        action: {}
      default: []
    G6_Press_off:
      name: Group 6 press off
      selector:
        action: {}
      default: []
    G1_Hold_on:
      name: Group 1 (All) hold on
      selector:
        action: {}
      default: []
    G1_Release_on:
      name: Group 1 (All) release on
      selector:
        action: {}
      default: []
    G1_Hold_off:
      name: Group 1 (All) hold off
      selector:
        action: {}
      default: []
    G1_Release_off:
      name: Group 1 (All) release off
      selector:
        action: {}
      default: []
    G2_Hold_on:
      name: Group 2 hold on
      selector:
        action: {}
      default: []
    G2_Release_on:
      name: Group 2 release on
      selector:
        action: {}
      default: []
    G2_Hold_off:
      name: Group 2 hold off
      selector:
        action: {}
      default: []
    G2_Release_off:
      name: Group 2 release off
      selector:
        action: {}
      default: []
    G3_Hold_on:
      name: Group 3 hold on
      selector:
        action: {}
      default: []
    G3_Release_on:
      name: Group 3 release on
      selector:
        action: {}
      default: []
    G3_Hold_off:
      name: Group 3 hold off
      selector:
        action: {}
      default: []
    G3_Release_off:
      name: Group 3 release off
      selector:
        action: {}
      default: []
    G4_Hold_on:
      name: Group 4 hold on
      selector:
        action: {}
      default: []
    G4_Release_on:
      name: Group 4 release on
      selector:
        action: {}
      default: []
    G4_Hold_off:
      name: Group 4 hold off
      selector:
        action: {}
      default: []
    G4_Release_off:
      name: Group 4 release off
      selector:
        action: {}
      default: []
    G5_Hold_on:
      name: Group 5 hold on
      selector:
        action: {}
      default: []
    G5_Release_on:
      name: Group 5 release on
      selector:
        action: {}
      default: []
    G5_Hold_off:
      name: Group 5 hold off
      selector:
        action: {}
      default: []
    G5_Release_off:
      name: Group 5 release off
      selector:
        action: {}
      default: []
    G6_Hold_on:
      name: Group 6 hold on
      selector:
        action: {}
      default: []
    G6_Release_on:
      name: Group 6 release on
      selector:
        action: {}
      default: []
    G6_Hold_off:
      name: Group 6 hold off
      selector:
        action: {}
      default: []
    G6_Release_off:
      name: Group 6 release off
      selector:
        action: {}
      default: []
mode: single
  - platform: event
    event_type: zwave_js_value_notification
variables:
  logger: blueprint.zwave_js_value_notification
  device_id: !input "remote_entity"
  - choose:
      - conditions:
          - condition: template
            value_template: "{{ trigger.event.data.device_id == device_id and trigger.event.data.command_class == 91 and (trigger.event.data.value == 'KeyPressed' or trigger.event.data.value == 'KeyHeldDown' or trigger.event.data.value == 'KeyReleased') }}"
        sequence:
          - choose:
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '001' and trigger.event.data.value == 'KeyPressed' }}"
                sequence: !input "G1_Press_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '002' and trigger.event.data.value == 'KeyPressed' }}"
                sequence: !input "G1_Press_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '003' and trigger.event.data.value == 'KeyPressed' }}"
                sequence: !input "G2_Press_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '004' and trigger.event.data.value == 'KeyPressed' }}"
                sequence: !input "G2_Press_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '005' and trigger.event.data.value == 'KeyPressed' }}"
                sequence: !input "G3_Press_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '006' and trigger.event.data.value == 'KeyPressed' }}"
                sequence: !input "G3_Press_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '007' and trigger.event.data.value == 'KeyPressed' }}"
                sequence: !input "G4_Press_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '008' and trigger.event.data.value == 'KeyPressed' }}"
                sequence: !input "G4_Press_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '009' and trigger.event.data.value == 'KeyPressed' }}"
                sequence: !input "G5_Press_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '010' and trigger.event.data.value == 'KeyPressed' }}"
                sequence: !input "G5_Press_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '011' and trigger.event.data.value == 'KeyPressed' }}"
                sequence: !input "G6_Press_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '012' and trigger.event.data.value == 'KeyPressed' }}"
                sequence: !input "G6_Press_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '001' and trigger.event.data.value == 'KeyHeldDown' }}"
                sequence: !input "G1_Hold_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '001' and trigger.event.data.value == 'KeyReleased' }}"
                sequence: !input "G1_Release_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '002' and trigger.event.data.value == 'KeyHeldDown' }}"
                sequence: !input "G1_Hold_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '002' and trigger.event.data.value == 'KeyReleased' }}"
                sequence: !input "G1_Release_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '003' and trigger.event.data.value == 'KeyHeldDown' }}"
                sequence: !input "G2_Hold_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '003' and trigger.event.data.value == 'KeyReleased' }}"
                sequence: !input "G2_Release_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '004' and trigger.event.data.value == 'KeyHeldDown' }}"
                sequence: !input "G2_Hold_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '004' and trigger.event.data.value == 'KeyReleased' }}"
                sequence: !input "G2_Release_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '005' and trigger.event.data.value == 'KeyHeldDown' }}"
                sequence: !input "G3_Hold_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '005' and trigger.event.data.value == 'KeyReleased' }}"
                sequence: !input "G3_Release_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '006' and trigger.event.data.value == 'KeyHeldDown' }}"
                sequence: !input "G3_Hold_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '006' and trigger.event.data.value == 'KeyReleased' }}"
                sequence: !input "G3_Release_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '007' and trigger.event.data.value == 'KeyHeldDown' }}"
                sequence: !input "G4_Hold_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '007' and trigger.event.data.value == 'KeyReleased' }}"
                sequence: !input "G4_Release_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '008' and trigger.event.data.value == 'KeyHeldDown' }}"
                sequence: !input "G4_Hold_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '008' and trigger.event.data.value == 'KeyReleased' }}"
                sequence: !input "G4_Release_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '009' and trigger.event.data.value == 'KeyHeldDown' }}"
                sequence: !input "G5_Hold_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '009' and trigger.event.data.value == 'KeyReleased' }}"
                sequence: !input "G5_Release_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '010' and trigger.event.data.value == 'KeyHeldDown' }}"
                sequence: !input "G5_Hold_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '010' and trigger.event.data.value == 'KeyReleased' }}"
                sequence: !input "G5_Release_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '011' and trigger.event.data.value == 'KeyHeldDown' }}"
                sequence: !input "G6_Hold_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '011' and trigger.event.data.value == 'KeyReleased' }}"
                sequence: !input "G6_Release_on"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '012' and trigger.event.data.value == 'KeyHeldDown' }}"
                sequence: !input "G6_Hold_off"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '012' and trigger.event.data.value == 'KeyReleased' }}"
                sequence: !input "G6_Release_off"
            default:
              - service: system_log.write
                  level: debug
                  logger: "{{ logger }}"
                  message:
                    Activated scene '{{ trigger.event.data.label }}' ({{ trigger.event.data.scene_id
                    }}) with value '{{ trigger.event.data.label }}' ({{ trigger.event.data.property_key
                    }}) for node '{{ remote_entity }}' ({{ trigger.event.data.node_id }})
    default: []
