zwa-2 migration from silabs fails
Trying to migrate from a silicon labs 700 series USB dongle to the new zwa-2 and it is a complete failure. The migration wizard runs and after unplugging the dongle I have a complete set of dead nodes with no name other than a node number. You can’t ping or rebuild the routes. You can manually remove all the dead nodes but then I’d have to open every switch and outlet box to get the codes to add the new devices back. If I put the dongle back I now have a second set of devices, that is all the originals and they all work. If I then try to remove the dead nodes it says I can’t because they are not dead. It can’t talk to them but they do answer a ping. Removing the dongle and the devices stay dead and stop answering the ping. No idea why this isn’t migrating. The docs say from a 500 series or 800 series but do not mention my 700 series silabs dongle.
