zWave - Aeotec Wallmont Template Sensor
Hello :slight_smile:
my Aeotec Wallmote works now :sunny: so now i will monitore the battery level…
i try it with this:
  sensors:
    zwave_Eingang:
      friendly_name: "ZWave - Batterie"
      icon_template: mdi:train
      value_template: '{{ states.zwave.aeotec_zw130_wallmote_quad.attributes.battery_level }}'
this will not work then i try it with
zwave_test:
  value_template: '{% if states.zwave.aeotec_zw130_wallmote_quadzwave %} {{ states.zwave.aeotec_zw130_wallmote_quadzwave.attributes.battery_level }} {% else %} Unknown {% endif %}'
  unit_of_measurement: '%'
—> = Unknown
but this don’t work… where i have the problem?
Your first template looks OK for getting the battery level, but you have an invalid entity ID name. Only lower case letters are allowed. I would use this:
  sensors:
    zwave_eingang:
      device_class: battery
      value_template: "{{ state_attr('zwave.aeotec_zw130_wallmote_quad', 'battery_level') }}"
If you want a battery icon that automatically reflects the percentage, remove the icon_template.
Your second template is basically doing the same work as state_attr(), but you are using the wrong entity name. states.zwave.aeotec_zw130_wallmote_quadzwave should just be states.zwave.aeotec_zw130_wallmote_quad.
Cool :smiley: thank you!
