Zwave config path
Hi
The config_path is optional for the zwave configuration. If ommited what is the default behaviour?
I read about some people creating a zwave config with ozwp and then copy it to the HA directory. When copying it to the HA directory should the parameter config_path be ommited in the configuration.yaml? or something else?
thanks!
If not specified I think it defaults to HA’s config directory.
I’ve personally created a symlink to the config of OZWCP in my HA config directory but I then specified this with the config_path variable.
