Zwave Device configuration (HA 2024.1.2)
I want to set Fibaro door sensor FGDW002 Parameter 1 to “Closed when magnet near”
After changing via dropdown there is just a grey dot showing.
But I can’t find a “Save”-Button.
How can I send the new parameter to my door sensor?
Regards
Chris
you do not use save for that. Just change the value and it will be placed in a queue and updated the next time, when the device wake up. To speed up the process, you can manually wake the device.
Thank you very much. It works after manually wake up.
