Zwave device more info cards
Pre. 47 when taping on a device switch or light in HA it showed the power consumption in the card is this intended to be added back in or can this be customised? I have had a look athe the development options but there is no default zwave card? Or perhaps on option to remove what is currently shown the old entity ids.
I think power consumption only shows if the device is reporting it. (ie: Power Meters,Outlets,Power Strips)
All my switches and dimmers report power consumption and they showed this on the more info card pre. 47 since the changes to node ids this is gone
Does the info show up in the dev tools, the icon on the left nav bar that looks like <> ?
yes shows as a sensor for the entity
If it now shows as a sensor, you’ll have to add that sensor in as a separate entity in your groups.xml to display it.
It always showed as a sensor before. 47 it was integrated into the card somehow and I didnt do a anything special it just worked
What brand/model of switch?
Qubino ZMNHBDx ZMNHADx
I have the same issue since 0.47.
I have Qubino dimmers and relays.
It doesn’t seem to be manufacturer specific it seems to effect all zwave lights/switches as I have 2 TKB plug in ones that don’t display this now either.
At this point, it’d be best to report the bug on github.
