Hello There,
I am running HA for about 2 months now, but the last 2 weeks my AEONLABS usb zwave is not responding to close my shutter.
When i power off my PI and turn it on again it works for about 1 day and then it stop again.
I was thinking about a hardware failure, but when i place the usb stick in my old domticz server it does respond.
I have some logs of zwave below here, hope someone can help me fix this.
Thanks.
2020-06-13 09:02:56.470 Info, Node002, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2020-06-13 09:02:56.470 Warning, Node002, WARNING: Device is not a sleeping node.
2020-06-13 09:02:56.470 Error, Node002, ERROR: node presumed dead
2020-06-13 09:02:56.470 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2020-06-13 09:02:56.470 Warning, CheckCompletedNodeQueries all=1, deadFound=1 sleepingOnly=1
2020-06-13 09:02:56.470 Info, Node query processing complete except for dead nodes.
2020-06-13 09:02:56.470 Info, Node002, QueryStageRetry stage CacheLoad requested stage CacheLoad max 3 retries 2 pending 1
2020-06-13 09:02:56.470 Detail, Node001, Expected callbackId was received
2020-06-13 09:02:56.470 Detail, Node001, Expected reply was received
2020-06-13 09:02:56.470 Detail, Node001, Message transaction complete
2020-06-13 09:02:56.470 Detail, Node002, Removing current message
2020-06-13 09:02:56.470 Detail, Node002, Notification: Notification - NoOperation
2020-06-13 09:02:56.472 Detail, contrlr, Notification: AllNodesQueriedSomeDead
2020-06-13 09:02:56.474 Detail, Node002, Notification: Notification - Node Dead
2020-06-13 09:02:56.476 Detail, Node002, Query Stage Complete (CacheLoad)
2020-06-13 09:02:56.476 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=0
2020-06-13 09:04:05.654 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Open - 1 - 1 - false
2020-06-13 09:04:05.655 Info, Node003, SwitchMultilevel::StopLevelChange - Stopping the level change
2020-06-13 09:04:05.655 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_StopLevelChange (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x05, 0x25, 0x10, 0xf2
2020-06-13 09:04:05.655 Detail, Node003, Queuing (Send) SwitchBinaryCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x25, 0x02, 0x25, 0x11, 0xf7
2020-06-13 09:04:05.655 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x12, 0xf7
2020-06-13 09:04:05.655 Detail, Node003, Queuing (Send) IndicatorCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x87, 0x02, 0x25, 0x13, 0x57
2020-06-13 09:04:05.655 Error, Node003, ERROR: Dropping command because node is presumed dead
2020-06-13 09:04:05.655 Detail, Node003, Removing current message
2020-06-13 09:04:05.656 Detail, Node003, Removing current message
2020-06-13 09:04:05.656 Error, Node003, ERROR: Dropping command because node is presumed dead
2020-06-13 09:04:07.153 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Close - 2 - 1 - true
2020-06-13 09:04:07.153 Info, Node003, SwitchMultilevel::StartLevelChange - Starting a level change
2020-06-13 09:04:07.153 Info, Node003, Direction: Down
2020-06-13 09:04:07.154 Info, Node003, Ignore Start Level: True
2020-06-13 09:04:07.154 Info, Node003, Start Level: 0
2020-06-13 09:04:07.154 Info, Node003, Duration: 255
2020-06-13 09:04:07.154 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_StartLevelChange (Node=3): 0x01, 0x0c, 0x00, 0x13, 0x03, 0x05, 0x26, 0x04, 0x60, 0x00, 0xff, 0x25, 0x14, 0x6a
2020-06-13 09:04:07.154 Error, Node003, ERROR: Dropping command because node is presumed dead
2020-06-13 09:04:07.154 Detail, Node003, Removing current message
