ZWave devices get renamed after Z-Wave.JS upgrades
Hi All,
Every now and then some of my devices get renamed to the default entity id name.
Just now with the last update to 0.1.51 it happened to 3 of my fibaro switched.
It becomes quite anoying to fix things after updates and would really like to see what causes this behaviour.
Some of you see this happening and what is the best approach to fix this.
The device renaming is a bug in HA (fixed in a next version), but is a symptom of bigger problems. You are probably experiencing errors during startup which cause the devices to become unknown. Usually this is a problem talking with the controller or communications problems with the nodes. You’d need to dig into the driver debug startup logs to get any further. These aren’t available in the official add-on, only zwavejs2mqtt.
