Here are my logs. I am running this on an unRAID server. I moved over (copy paste) my config from a Pi to my unRAID. But then i had issues logging in so I deleted my .storage folder and also .cloud as I also had an error on bad token for that too. Now they have disappeared. At first they were there right after I moved everything over.
Can anyone tell me what is going on? Under integrations I don’t see zwave. I am not sure if i should add this back or what.
2019-08-12 23:47:33.458 Detail, Node016, Refreshed Value: old value=false, new value=false, type=bool
2019-08-12 23:47:33.459 Detail, Node016, Changes to this value are not verified
2019-08-12 23:47:33.459 Info, Node016, Received Meter report from node 16: Current=1.09A
2019-08-12 23:47:33.459 Detail, Node016, Refreshed Value: old value=1.01, new value=1.09, type=decimal
2019-08-12 23:47:33.459 Info, Node016, Previous value was 1.01A, received 301 seconds ago.
2019-08-12 23:47:33.459 Detail, Node016, Refreshed Value: old value=1.00, new value=1.01, type=decimal
2019-08-12 23:47:33.459 Detail, Node016, Refreshed Value: old value=301, new value=301, type=int
2019-08-12 23:47:33.459 Detail, Node016, Notification: ValueChanged
2019-08-12 23:47:33.462 Detail, Node016, Notification: ValueChanged
2019-08-12 23:47:33.465 Detail, Node016, Notification: ValueChanged
2019-08-12 23:47:33.467 Detail, Node016, Notification: ValueChanged
2019-08-12 23:50:35.945 Info, mgr, Manager::WriteConfig completed for driver with home ID of 0xe66494b9
2019-08-12 23:50:36.983 Info, mgr, Driver for controller /dev/serial/by-id/usb-0658_0200-if00 pending removal
2019-08-12 23:50:36.983 Detail, Notification: DriverRemoved
2019-08-12 23:50:36.984 Always, ***************************************************************************
2019-08-12 23:50:36.984 Always, ********************* Cumulative Network Statistics *********************
2019-08-12 23:50:36.984 Always, *** General
2019-08-12 23:50:36.984 Always, Driver run time: . . . 0 days, 0 hours, 24 minutes
2019-08-12 23:50:36.984 Always, Frames processed: . . . . . . . . . . . . . . . . . . . . 324
2019-08-12 23:50:36.984 Detail, WriteMsg Wait Timeout m_currentMsg=00000000
2019-08-12 23:50:36.984 Always, Total messages successfully received: . . . . . . . . . . 324
2019-08-12 23:50:36.984 Always, Total Messages successfully sent: . . . . . . . . . . . . 124
2019-08-12 23:50:36.984 Always, ACKs received from controller: . . . . . . . . . . . . . 123
2019-08-12 23:50:36.984 Always, *** Errors
2019-08-12 23:50:36.984 Always, Unsolicited messages received while waiting for ACK: . . 1
2019-08-12 23:50:36.984 Always, Reads aborted due to timeouts: . . . . . . . . . . . . . 0
2019-08-12 23:50:36.984 Always, Bad checksum errors: . . . . . . . . . . . . . . . . . . 0
2019-08-12 23:50:36.984 Always, CANs received from controller: . . . . . . . . . . . . . 1
2019-08-12 23:50:36.985 Always, NAKs received from controller: . . . . . . . . . . . . . 0
2019-08-12 23:50:36.985 Always, Out of frame data flow errors: . . . . . . . . . . . . . 0
2019-08-12 23:50:36.985 Always, Messages retransmitted: . . . . . . . . . . . . . . . . . 1
2019-08-12 23:50:36.985 Always, Messages dropped and not delivered: . . . . . . . . . . . 6
2019-08-12 23:50:36.985 Always, ***************************************************************************
2019-08-12 23:50:39.034 Info, mgr, Driver for controller /dev/serial/by-id/usb-0658_0200-if00 removed
2019-08-12 23:50:40.035 Error, mgr, Manager::GetDriver failed - Home ID 0xe66494b9 is unknown
2019-08-12 23:50:40.035 Warning, Exception: Manager.cpp:373 - 100 - Invalid HomeId passed to GetDriver
2019-08-12 23:50:40.035 Info, mgr, GetSendQueueCount() failed - _homeId -429615943 not found
