Zwave devices not responding after migrating from ZST10 to ZST39
I recently migrated from a ZST10 controller to a ZST39 controller using using the NVM backup and restore feature in ZWave JS UI. The process worked fine and all my nodes are showing correctly using the ZST39 controller. Most of the nodes function normally, but I have a few switches that won’t respond to on/off commands from Home Assistant and do not update their on/off status in HA when manually turned on/off. The switches still show active in the UI and their “Last Active” status info updates normally to show when they were last turned on/off manually or in HA.
Any suggestions on how I can rectify this? I’ve cycled my HAOS machine a number of times.
Suggest going into ZWaveJS-UI and reinterview one of the nodes that is not responding, and check the ZWaveJS-UI logs along the way to see if there are any problems.
