Zwave Entity Confusion
I just installed 4 zwave fan switches.
I am using an Aeon Labs Zwave stick on a Nuc running hassio on a unRAID Linux VM.
I now have the following entities showing.
fan.jasco_products_14287_fan_control_switch_level
fan.jasco_products_14287_fan_control_switch_level_2
fan.jasco_products_14287_fan_control_switch_level_3
fan.jasco_products_14287_fan_control_switch_level_4
zwave.aeon_labs_zw090_z_stick_gen5_us
zwave.jasco_products_14287_fan_control_switch
zwave.jasco_products_14287_fan_control_switch_2
zwave.jasco_products_14287_fan_control_switch_3
zwave.jasco_products_14287_fan_control_switch_4
Also on the Integrations page zwave shows all of the fan switches.
The entities that control the fans are the ones that start with fan.jasco.
Do I have to worry about the others or have I done something wrong in my setup.
Any help is greatly appreciated.
The fan. entities are the ones you’ll use to control your fans. The zwave. entities just give you information on the Z-Wave node /communication. You don’t need to do anything with them. though you can check their state/attributes to see if you’re having communication issues with any of the devices.
Thank you.
That is sort of what I thought, but wanted to make sure.
Appreciate the help.
