Zwave fails to migrate via Backup / Restore from Pi3 to Pi4
It almost looks like the Gen 5 stick is not seen via USB? Even if I unplug / plug it.
All of my devices are show in Home assistant, just not active.
If I try to manually start Zwave add on…
   Missing required option 'device' in Z-Wave JS (core_zwave_js)
If I attempt to reconfigure the add on it doesn’t show the USB and None of the keys show.
If I attempt to delete & re-install it still acts as if it doesn’t recognize the USB stick.
What am I doing wrong?
Thanks in Advance!
Log details (ERROR)
Logger: homeassistant.components.zwave_js
Source: components/hassio/addon_manager.py:410
integration: Z-Wave (documentation, issues)
First occurred: 4:55:28 PM (11 occurrences)
Last logged: 5:04:49 PM
  • Failed to set the Z-Wave JS add-on options: not a valid value for dictionary value @ data[‘options’]. Got {‘device’: ‘/dev/serial/by-id/usb-0658_0200-if00’, ‘s0_legacy_key’: ‘2CA4A2A03FDB32A0F8B5801947E4231A’, ‘s2_access_control_key’: ‘22D3FAB8977666645F6E4457083EF52C’, ‘s2_authenticated_key’: ‘15851988944A67BA83BDAB74BEE4492B’, ‘s2_unauthenticated_key’: ‘DCA56C5A306A143AA71D3964CD829035’}
  • Failed to set the Z-Wave JS add-on options: not a valid value for dictionary value @ data[‘options’]. Got {‘device’: ‘/dev/serial/by-id/usb-0658_0200-if00’, ‘s0_legacy_key’: ‘2CA4A2A03FDB32A0F8B5801947E4231A’, ‘s2_access_control_key’: ‘22D3FAB8977666645F6E4457083EF52C’, ‘s2_authenticated_key’: ‘15851988944A67BA83BDAB74BEE4492B’, ‘s2_unauthenticated_key’: ‘DCA56C5A306A143AA71D3964CD829035’, ‘lr_s2_access_control_key’: ‘0538109B5819952BB327713542EFA6E4’, ‘lr_s2_authenticated_key’: ‘A724BE6E6A161EF9B5E255BBD3BAD2E0’}
Use a powered USB-hub between the Pi4 and the ZWave stick
