ZWave: How to apply device specific configuration?
I have a Devolo MT02648 Door Sensor which is working fine in Home Assistant. I found the page where one can set the Z-Wave parameters supported for the device and started to change them as needed.
I am missing an “apply” button or similar, though. I can change the values; the white dot indicates a change, but how do I apply the changes? If I navigate back and forth, the changes are gone and my device still behaves as before.
How can I apply the changed settings?
With most Z-wave devices that are battery operated it will update when the device wakes up.
Mhh I read that as well and manually woke the device after changing the settings. Still it does not seem to be applied.
maybe my work flow is wrong?
  1. I go to the page
  2. change the settings
  3. leave the page open and go wake up the device by opening the door.
  4. wait a few seconds
  5. Refresh page
  6. Parameters are now changed back to the default, not what I entered.
I found that the device triggering i,e. opening the door and the device waking up seem to be two different things, some devices have a wake button I have some z-wave buttons and on the back there is a button to press that wakes them up, some devices seem to wake when I ping them, some I have to push the reset button quickly to wake them.
For yours this looks like what they are saying…
“The wakeup interval is a tradeoff between maximal battery life time and the desired responses of the device. To wakeup the device please perform the following action: There are two tamper keys in the device, one is in the back side, another is in the front side. Both of them can add, remove, reset or association from Z-Wave network. Press any key once, the device will awake 10 seconds.”
  1. leave the page open and go wake up the device by opening the door.
That is not how you wake up a Z-Wave device. The manual states that you have press the tamper key once to wake the device up. Product Network Management Instructions
How to Tell if a device is awake in Z-Wave JS Integration
How to tell if a device is awake in the Z-Wave JS UI Control Panel. Orange Zs mean asleep and green smiley means awake.
Sleep Awake
