Zwave JS Can't add
I use a VM with HA. I started having issues with Zwave Js dropping nodes. I can reinterview them to get them back but they drop again after a while. I tried excluding the node then including it again and found I can’t add it again. I’ve tried severaql different brandsa and none of them work anymore. QR code won’t work either.
I’m using a Zooz S2 Stick ZST10
Logs are saying:
2025-02-24T21:28:26.724Z CNTRLR   Starting inclusion process with strategy Default...
2025-02-24T21:28:26.734Z CNTRLR   The controller is now ready to add nodes
2025-02-24T21:28:31.687Z CNTRLR   [Node 059] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:28:32.947Z CNTRLR   [Node 031] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:28:36.136Z CNTRLR   [Node 059] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:28:57.278Z CNTRLR   [Node 031] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:28:58.949Z CNTRLR   [Node 023] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:29:01.805Z CNTRLR   [Node 042] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:29:03.067Z CNTRLR   [Node 096] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:29:05.761Z CNTRLR   [Node 014] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:29:07.212Z CNTRLR   [Node 023] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:29:09.664Z CNTRLR   [Node 042] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:29:11.087Z CNTRLR   [Node 028] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:29:13.626Z CNTRLR   [Node 096] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:29:33.473Z CNTRLR   [Node 041] The node did not respond after 1 attempts, it is presumed dead
2025-02-24T21:29:33.475Z CNTRLR   [Node 041] The node is now dead.
2025-02-24T21:29:34.744Z CNTRLR   [Node 059] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:29:37.467Z CNTRLR   [Node 031] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:29:58.174Z CNTRLR   [Node 059] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:29:59.298Z CNTRLR   [Node 023] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:30:01.904Z CNTRLR   [Node 042] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:30:03.296Z CNTRLR   [Node 096] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:30:10.582Z CNTRLR   stopping inclusion process...
2025-02-24T21:30:31.085Z CNTRLR   [Node 031] Timed out while waiting for a response from the node (ZW0201)
2025-02-24T21:30:31.155Z CNTRLR   The inclusion process was stopped
I can’t even figure out what nodes these are.
Any help would be greatly appreciated.
