updated to ZWave JS UI 1.62 with HA 2023.2.2 and was getting an error that could connect to my Z-wave controller. Deleted the integration to start from fresh. HA does detect the integration but fails to set it up. Here the error I get:
2023-02-06 11:29:50.136 ERROR MQTT: Mqtt client error Connection refused: Not authorized
Error: Connection refused: Not authorized
at MqttClient._handleConnack (/opt/node_modules/mqtt/lib/client.js:1388:17)
at MqttClient._handlePacket (/opt/node_modules/mqtt/lib/client.js:549:12)
at work (/opt/node_modules/mqtt/lib/client.js:438:12)
at Writable.writable._write (/opt/node_modules/mqtt/lib/client.js:452:5)
at doWrite (/opt/node_modules/readable-stream/lib/_stream_writable.js:409:139)
at writeOrBuffer (/opt/node_modules/readable-stream/lib/_stream_writable.js:398:5)
at Writable.write (/opt/node_modules/readable-stream/lib/_stream_writable.js:307:11)
at Socket.ondata (node:internal/streams/readable:766:22)
at Socket.emit (node:events:513:28)
at Socket.emit (node:domain:489:12)
Anyone can help?
