pdwonline
(When a goat is on the net)
February 22, 2024, 1:08pm
1
My log shows this:
Logger: homeassistant.components.zwave_js.services
Source: components/zwave_js/services.py:769
This service is deprecated in favor of the ping button entity. Service calls will still work for now but the service will be removed in a future release
However, I do use this because the Philio PAN04 zwave switch does actively report its status. This is an example part of my code:
- service: zwave_js.refresh_value
entity_id:
- switch.light_toilet
- switch.fan_living_speed_1
- switch.fan_living_speed_2
- delay: "00:00:01"
- condition: state
entity_id: switch.fan_living_speed_2
state: 'off'
Does this mean I have to replace it with something like this?
- service: zwave_js.ping
entity_id:
- delay: "00:00:01"
- condition: state
state: 'off'
petro
(Petro)
February 22, 2024, 1:29pm
2
Yes or you can use the button entities with the button.press service.
pdwonline
February 22, 2024, 1:54pm
3
Seems not. Experimented with this. service: zwave_js.ping
is still a member of service: zwave_js
and that seems to get removed. I should use the ping button now. Code to call that is like:
service: button.press
entity_id: button.ventilator_toilet_ping
data: {}
not sure if I can call mutiple entities here in one call. Also notice that this is a refresh on device level instead of entity level. This means that a ping will refresh all enitites for the device, generating probably much more traffic than the old service call.
I do not understand why these breaking changes are made so often…
petro
(Petro)
February 22, 2024, 1:55pm
4
This change was made almost 2 years ago.
entity_id
in target
, at the root level of the service call, and inside service data
always accepts a list of entities.
pdwonline
February 22, 2024, 2:01pm
5
How do I modify my watcher that pings nodes that seems dead:
alias: Act on failed Zwave Nodes
description: ''
- platform: state
entity_id: sensor.failed_zwave
- delay: '00:02:00'
- condition: template
value_template: >
states.sensor.failed_zwave.state != "[]" and
states.sensor.failed_zwave.state != "unknown"
entity_id: '{{ states.sensor.failed_zwave.state }}'
- service: logbook.log
name: Dead node ping
message: 'The following nodes have been pinged {{ states.sensor.failed_zwave.state }}'
- delay: '00:01:00'
mode: single
petro
(Petro)
February 22, 2024, 2:07pm
6
You’ll have to share what sensor.failed_zwave
is outputting as the state.
pdwonline
February 22, 2024, 3:00pm
7
This is the sensor:
template:
- unique_id: Failed-Zwave-Sensor
icon: mdi:texture
state: >
{{ states | selectattr("entity_id", "search", "node_status") |
selectattr('state', 'in', 'dead, unavailable, unknown') |
map(attribute='entity_id') | list
it has a list of entity Id’s (but not the id’s of the ping button attached to the device)
petro
(Petro)
February 22, 2024, 3:22pm
8
You’ll run into issues with that old template and the state character limit, you should be using an attribute.
As for the changes to make this happen, use this template…
template:
icon: mdi:clock
state:>
{{ integration_entities('zwave_js')
| select('search', 'node_status')
| select('is_state', ['dead', 'unknown', 'unavailable'])
| list | count }}
attributes:
dead: >
| map('device_id')
| map('device_entities')
| sum(start=[])
| select('search', '^button')
| select('search','ping') | list }}
And then your automation will be…
description: ''
- platform: state
condition:
value_template: "{{ trigger.to_state.state | int > 0 }}"
- service: button.press
entity_id: '{{ trigger.to_state.attributes.dead }}'
message: The following devices have been pinged {{ trigger.to_state.attributes.dead | map('device_attr','name') | list | join(',') }}
mode: single
rodders_UK
(Rodders_UK)
February 27, 2024, 4:45pm
10
Here’s how I updated my z-wave ping :
- id: 'mains_power_plug_ping'
alias: mains power ping power plug
description: Ping Z-Wave power plug every minute
- platform: time_pattern
minutes: "/1"
condition: []
entity_id: button.heater_ping
data: {}
mode: single
