These instructions assume that you know how to install and navigate your OS on your device.
Install Raspberry Raspbian with desktop either for the raspberry pi or desktop PC depending on your hardware.
Initial setup of Raspberry Raspbian is easier with monitor keyboard and mouse hooked up local to your device.
Enable SSH in configuration, once you have enabled SSH then remote configuring is preferred for below instructions.
You can copy and paste below commands into the terminal, these instructions assume you have knowledge on the ability to SSH into your device.
Copy and paste is the easiest, and PuTTY allows right click paste.
These steps use the default user of pi, so if using different then what is default make changes as needed.
(Note some stuff will not work fully until all the steps have been done IE shared folders won’t connect until that directory is made.)
This instruction will do the following:
Will allow network shares of certain folders for editing and backing up your configuration of files and access to root directory.
((WARNING MESSING AROUND IN ROOT DIR CAN BREAK YOUR INSTALL)) -
Will install Zwave-JS2MQTT server onto your device.
Will allow Zwave-JS Server to restart after a reboot.
“BELOW IS LINKS TO EITHER X86-64 INSTALL OR ARM INSTALL”
To install on a x86-64 platform select this link.
x86-64 Platform -
To install on a ARM platform select this link Arm Platform
