ZWave JS setting Wakeup Interval using the set parameter?
I am using the websocket version of Zwave JS and it is very fast and responsive but some devices I had to factory reset to get working again. I can now change the parameters on these devices with the new update but I cannot figure out how to set the wakeup interval on the battery devices, are there a setting parameter for this? On the old Zwave panel it was a separate field for all devices.
Thanks in advance and great job everyone!
/Matt
No, it’s not supported yet. You would have to use the zwavejs2mqtt addon and control panel instead, or use raw websocket commands.
Okay, thanks for your response. I was looking like mad for the wakeup parameter without finding it!
I can wait for it to be supported, it is only one sensor and the default is good enough for now.
I have too been looking for this. I think it would be a solution to why the battery level never updates.
So my vote for this feature.
