ZWave JS won't start
Getting this in the log - and my ZWA-2 seems to have vanished from HA - also its pulsing a blue light. Any ideas?
If I look in the Z-wave JS settings I see this:
Failed setup, will retry: Failed to connect: Cannot connect to host a0d7b954-zwavejs2mqtt:3000 ssl:default [Connect call failed (‘172.30.33.1’, 3000)]
Home Assistant Supervisor:
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
jq: error: syntax error, unexpected IDENT, expecting '|' or ',' or ';' at <builtin>, line 56, column 17:
    def iterables: 3elect(type|. == "array" or . == "object");
Assertion failed: !nerrors (src/builtin.c: builtins_bind: 2062)
[13:45:43] FATAL: Unknown log_level:
s6-rc: warning: unable to start service base-addon-log-level: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: warning: service s6rc-oneshot-runner is marked as essential, not stopping it
An update - I’ve done a restore from 2 days ago and its back online.
ZWA-2 became unnavailable at 17:30 last night - I did nothing… I was out!
Ahhhh! - In my restore I can see a Z-Wave JS update pending! - I remember kicking it off just before I went out! It was the update.
