Other than the sensitivity dial I’m not sure. It may be defective. I have 2 and to the best of my recollection, other than setting them to binary I did nothing but add in to my network and they worked.
Perhaps do a full reset on them and try again if you have not already. It would be odd that 2 would be like that. I did receive 1 dud from Amazon a while back.
honestly I ignore the burglary circle and look at the alarm state information directly. Aeotec stuff needs some configurations sent to them to make them report specific alarm types I spent hours trying to get my aeotec door switches to have anything other than a 2 in the burglar circle and realized that it’s not with it just to make a number in a circle on the web page what I want, I want the action to happen… I just use the sensor state in my scripting as that seems to be extremely reliable.
From what I can tell that is just an information indicator, and not used for anything else. Mine changes to a 3 when I trigger the tamper switch.
A bit more info, if have the burglar now at 7, it triggered yesterday evening and stayed at 7 all day long…
Could it be a parameter i’m missing somewhere ?
did you edit your options.xml to use encryption and did you join the sensors securely (add_node_secure) ? when doing so the sensor works as designed when changing it to binary - at least in my tests …
