Zwave neo coolcam switch. Where are they
I just installed the aeon stick, a neo coolcam pir sensor and a neo coolcam zwavve switch
In my states I have the pir sensor
sensor.neo_coolcam_battery_powered_pir_sensor_burglar_2_10	0	node_id: 2
friendly_name: Neo CoolCam Battery Powered PIR Sensor Burglar
sensor.neo_coolcam_battery_powered_pir_sensor_luminance_2_3	232.0	node_id: 2
friendly_name: Neo CoolCam Battery Powered PIR Sensor Luminance
unit_of_measurement: lux
sensor.neo_coolcam_battery_powered_pir_sensor_sourcenodeid_2_2	0	node_id: 2
friendly_name: Neo CoolCam Battery Powered PIR Sensor SourceNodeId
and this 2 items. I guess the first is the stick, and the second is the switch??? If yes how to controll it?
zwave.__1	Ready	capabilities: listening,beaming,primaryController
is_ready: true
node_id: 1
friendly_name:
is_awake: true
max_baud_rate: 40000
is_zwave_plus: false
is_info_received: false
query_stage: Complete
is_failed: false
zwave.__2	Ready	capabilities: beaming,routing
wake_up_interval: 300
node_id: 2
is_awake: true
is_info_received: true
is_failed: false
is_ready: true
is_zwave_plus: true
friendly_name:
neighbors: 1
battery_level: 100
did you get this sorted? I am looking at buying some of the switches
Hi there, have you tried to restart home assistant? Usually, after restarting, it pulls all the info needed, and you’re able to recognise each zwave device
